Author Topic: PixelMath image create mode behavior  (Read 1274 times)
Offline Buzz
    • The Astrophotography Manual - support
« on: 2017 February 26 04:37:40 »
If I have a simple PixelMath equation of the form  (image1*.3)+(image2*.7), where image 1 and 2 are grey  and create a new image, the mode of the image changes according to the mode of the selected image window. If that happens to be a completely different RGB image, the mode of the created image becomes RGB too, even though it is the sum of two monochrome images.
regards
Chris
Offline oldwexi
    • Astronomy Pages G.W.
Re: PixelMath image create mode behavior
« Reply #1 on: 2017 February 26 10:13:17 »
In the lower part of the PixelMath window - Destination -
You can select in "Color space:" either :
as target (which leads to your issue)  or
RGB Color or
Grayscale
select Grayscale and everything should be fine.
Gerald
Offline Buzz
« Reply #2 on: 2017 February 26 11:18:49 »
Aha!
thanks for that Gerald
regards
Chris
