Author Topic: Subframe Selector Script problem  (Read 2237 times)
Offline Mick G
« on: 2017 February 12 17:34:31 »
I am using the Subframe Selector Script and when I clicked the measure button, all the data seemed OK except the entire Weight column is 0's. Is this normal or did I do something wrong, and if so What?
Thanks for your help.
Mick
Offline mschuster
Re: Subframe Selector Script problem
« Reply #1 on: 2017 February 12 18:04:58 »
Sorry for the trouble. Please double check Expressions > Weighting, which defines Weight column values. If the expression is invalid you will see a red cross indicating an error and the weight column will be zero. Also check the terms used in the expression, sometimes the script is not able to successfully measure terms on some frames, and zeros are possible as a result. You might also try a different expression, to see if you can get something useful.
Offline Mick G
« Reply #2 on: 2017 February 13 18:01:04 »
Thanks, My mistake.  This is the first time I am using this tool.
Your quick response is really appreciated.
Mick
