Author Topic: Problem with flat in BPP  (Read 2484 times)
Offline JGMoreau
« on: 2017 February 02 11:36:20 »
Hi, I have the following problem using batch pre processing with master flat:
it is not recognized by BPP and not applied to the final image.
You can see the master flat I used with statistics.
What is wrong ?
I also have a QHY163C and I use similar technique to make my master flat, no problem.
Any help greatly appreciated.
JG Moreau
Québec
Offline JGMoreau
Re: Problem with flat in BPP
« Reply #1 on: 2017 February 04 07:08:05 »
Hi, I may never know what was wrong with my flat, but I solved the issue by making new flats
exactly the same way, and they work, go figure.
Doing so, I learned a few things, master flat created by BPP with mean of 0.5 is overcorrecting my image a lot,
while 0.3 is better. I took two series of exposures for the flats, T shirt over scope on darkening sky.
Furthermore, I had better correction using RAW flats frames in BPP rather than the one it created.
Hope it will help someone.
JG Moreau
Offline JGMoreau
« Reply #2 on: 2017 February 04 08:25:10 »
I meant the Master flat made by BPP rather that "the one created by BPP"
Offline kolec
« Reply #3 on: 2017 February 04 09:03:20 »
Try use "add custom" for loading master flat.
kolec
Offline JGMoreau
« Reply #4 on: 2017 February 05 09:41:25 »
Thanks Kolec for the suggestion, will do.
Just ordered "The Book"
JGM
