Author Topic: REPOSITORY INFORMATION  (Read 1914 times)
Offline Jlutkin
« on: 2017 January 23 13:57:09 »
FOR THE LAST FEW DAYS
UPON START UP I GET A MESSAGE
UNABLE TO DOWNLOAD REPOSITORY INFORMATION
THE ERROR LOG SHOWS THE FOLLOWING.
https://pixinsight.com/update/: Network error: Could not resolve host: pixinsight.com
https://pixinsight.com/update-doc/: Network error: Could not resolve host: pixinsight.com
COULD YOU TELL ME IF THIS IS AN ISSUE WITH MY COMPUTER OR IS THERE SOMETHING HAPPENING AT YOUR END.
APPART FROM PIXINSIGHT MY SYSTEM SEEMS TO BE FUNCTIONING NORMALLY.
REGARDS
JOHN
Re: REPOSITORY INFORMATION
« Reply #1 on: 2017 January 23 14:26:58 »
Hi John,
Sorry I can't help you directly - but I would like to ask you to avoid using ALL CAPITALS when you post questions (except where appropriate, to emphasize something - and, even then, there are HTML formatting tools available on the Forum that can give your text a bold, italic or underlined emphasis, or even a combination of all three, although I can't think why this would ever be needed  :) )
'All Capitals' tends to come across all 'shouty', and leaves folk disinclined to reply.
That said, I am sorry I don't have direct experience of your problem, so cannot help you myself - perhaps others can?
« Reply #2 on: 2017 January 23 15:49:19 »
HI JOHN....just kidding about the all caps. :cheesy:
You might look at this posting. http://pixinsight.com/forum/index.php?topic=7521.msg50230#msg50230 The last response by Jim.
Offline Jlutkin
« Reply #3 on: 2017 January 24 14:44:59 »
my apologies all round, I am rather hard of hearing and my key board was stuck in capitals.
John
« Reply #4 on: 2017 January 24 15:02:28 »
No problems from me John. I go back to the paper tape days when all we had were capitals letters. Somewhere in the garage I think I still have a portable terminal that doesn't code lower case.
Offline Jlutkin
« Reply #5 on: 2017 January 27 11:26:27 »
Good Evening, I report total failure from all your splendid advice. I have also included a uninstall and re install in the repertoire but I continue to be denied access to the repository. Most frustrating all round.
I am running Win10 inside VMware Fusion on a iMac loaded with Sierra.
If anyone has any addition thoughts as to what might be the problem I would appreciate any advice.
John
« Reply #6 on: 2017 January 27 12:21:16 »
from within the virtual machine can you use a web browser to go to pixinsight.com? the error seems to be that windows, or your router, can't translate the "pixinsight.com" to the IP address of pixinsight's server. this is something that all computers need to do to access any resource on the internet...  obviously whatever computer you are using to post on the forum is able to resolve pixinsight.com, or else you would not be able to post here.
also why not just run pixinsight on MacOS directly?
Offline Jlutkin
« Reply #7 on: 2017 January 28 02:25:15 »
Thank You I am well out of my depth here but I am using the same computer to access the forum. I can access all the items on the Resources tab except Down Load Updates. A puzzle indeed.
I have loaded PI onto the Mac and that works fine.
Thanks for the reply.
John
