Author Topic: Need some help with DBE  (Read 2628 times)
Offline wkrispler
« on: 2017 January 22 03:17:12 »
I am currently working on IC447 (example attached). Now I want to do DBE but I am lost because in this image I do
not find any background.
How would you approach DBE in such an image?
Thank you,
Wolfgang
Offline biosif
    • http://www.astrobin.com/users/iosifbodnariu/
Re: Need some help with DBE
« Reply #1 on: 2017 January 22 03:52:52 »
Hi.
In image below you have an example, and i think you can understand the proces to help you.
Iosif.
Tak FSQ85, FLI ML 8300, CGEM.
Offline wkrispler
« Reply #2 on: 2017 January 22 05:29:55 »
Hi Iosif,
so your recommendation is to use ABE instead of DBE with substraction? According to the Pixinsight documentation ABE should only be used in simple
cases where a lot of background is visible but this is more a complex case...
Background Neutralization etc is clear for me, I have done quite a lot of images already.
My question is refering to DBE or ABE only where to put the samples if no background is visible..
THank you,
Wolfgang
Offline aworonow
    • Faint Light Photography
« Reply #3 on: 2017 January 22 07:40:01 »
It appears you have fairly nebula-free sky above center, in the upper-right and upper-left corner regions. You can used the 'symmetry' part of DBE if you assume that the gradients are fairly symmetrical about the center. I've shown one point and its vertical & diagonal equivalents. (See the check marks in the upper area of the DBE control window.) I presume the procedure would take those to symmetrical points and assume the same qualities for them as the initial point in the upper-right quadrant.
Also, note that you can drag the white lines (which define the center of symmetry, etc) around.
Finally, do the background adjustment while the images are linear.
Alex
