Author Topic: working with .ARW file  (Read 2380 times)
Offline avan1
« on: 2016 December 20 14:46:26 »
Hi ,
     Just installed the update packages and can no longer work with sony .arw file .
please check the attachment for the  error  message.
Regard,
noodle :)
Re: working with .ARW file
« Reply #1 on: 2016 December 20 16:12:14 »
I'm not having any issues with my NEX-5 files after the update today. Windows 7 system.
Offline avan1
« Reply #2 on: 2016 December 20 16:54:21 »
Hi ,
     I can open the file but fail to do the batchpreprocessing .
Any idea ??
noodle
« Reply #3 on: 2016 December 20 17:51:48 »
I just tried BPP and had the same result as you did. I then used a set of bias, dark and flat masters and BPP completed correctly. Next I went to make a Bias master directly with the ARW files in ImageIntegration and PI crashed. I've never had this happen before.
Juan--I am uploading to my google drive a small set of bias, darks, flats and lights that can be used for testing. As soon as the upload is complete I can send you the link if you would like.
« Reply #4 on: 2016 December 20 18:12:56 »
Ran one more test. I did a batch Format Conversion of all files to .xisf and then ran BatchPrePreprocessing as normal. The script completed and I got a normal picture. At least that is a way around this until the problem can be fixed.
Offline avan1
« Reply #5 on: 2016 December 20 21:01:00 »
Thank you   ;D
« Reply #6 on: 2016 December 21 01:14:24 »
Bug fixed! I have just released the update to the DSLR_RAW module that I forgot to release yesterday. Things that happen when one is working too much and too late (and getting older, too...). Sorry for the trouble.
The problem was that the DSLR_RAW module does not support concurrent accesses, mainly because it uses some static data that is rewritten each time a new file is loaded from disk. The update simply synchronizes file accesses from modules to prevent concurrency. The new versions of StarAlignment and ImageIntegration implement high-level parallel I/O for the first time in PixInsight, which has exposed this issue.
Let me know if you encounter further problems, I hope not.
Mike, of course if you upload raw data for testing, that will be of great help for me. Fresh testing data always helps. Thank you!
Offline avan1
« Reply #7 on: 2016 December 21 04:30:50 »
 BPP can now work correctly  ;D
Thank you
