Author Topic: Issues with imagesolver  (Read 1750 times)
Offline Udo.Zlender
« on: 2016 December 16 06:28:41 »
I must report problems with imagesolver. There is no correspondence between my coordinates and e.g. DSS when I load the platesolved frames into aladin. So I tried  http://nova.astrometry.net/upload where I received correct results.
Udo
Offline Andres.Pozo
Re: Issues with imagesolver
« Reply #1 on: 2016 December 17 03:39:55 »
I would need the image where you have problems in order to find the problem.
Offline Udo.Zlender
« Reply #2 on: 2016 December 19 04:22:34 »
Hello Andres,
Sorry for my late reply. The two images are about 3 MByte each. To which adress shall I send them?
Udo
Offline Andres.Pozo
« Reply #3 on: 2016 December 19 06:11:47 »
You can use Dropbox or something similar. PM me if you don't want to put the url's in the open.
I would also need to know the steps to reproduce the problem.
Offline Andres.Pozo
« Reply #4 on: 2016 December 27 12:08:01 »
Hi Udo,
the problem with your image is easy to solve. You only have to change one of the options in the FITS module: Open "Format explorer", select FITS and click in the button "Edit preferences" to open the options of the FITS format. Change the option "Coordinate origin" to "Lower left corner (bottom-up)".
Now when you save a solved image, the result will be compatible with applications that expect this coordinate origin.
Juan designed the XIFS format because of many problems like this with the FITS format. The funny thing is that this is unambiguously defined in the FITS specification (the files should be stored bottom-up). However historically the amateur tools have saved/read FITS files "Up-bottom". Old versions of PixInsight defaulted to the "professional" standard  but I suppose Juan changed it to "Up-botton" to maximize the compatibility with other tools, although this not seems to be typical of Juan  >:D >:D.
Andrés.
