Author Topic: Local Flat error correction (rejection)  (Read 1895 times)
Offline ngc1535
« on: 2016 December 14 22:55:18 »
After calibrating light frames I occasionally find that some flat errors remain in a particular night's data. A typical example is that flats are generated at the end of the night. At some point in the middle of the night a dust mote or other thing falls on an optical surface in front of the camera. Although the newly generated flats will correct images taken after the dust mote fell- they will not help for images at the beginning of the night.
So as part of the image integration and rejection process is there a method to locally select these areas in the problem images to have them be rejected pixels (in addition to normal statistical rejection)?
-Adam
