Author Topic: Batch preprocessing turn computer off  (Read 1003 times)
Offline fgbarr
« on: 2016 November 23 08:32:19 »
I'm new in Pixinsight (1.8 with last update) and using Canon SL1 DSLR files.  In this case I have 45 Bias, 23 Darks and 44 Lights.  I can use any number of Darks and Lights files to process and it is OK, but I can't use more than 6 bias because the computer turns off (Like if you  press the on/off button for 8 seconds) when preprocessing Bias files. I discover it doing many simulations.  Is it a Bug?  I'm using default parameters suggested by many  processing videos for DSLR process.
Computer Dell Vostro Notebook i5.  Windows 10 pro.
I'm doing some more testes and it appears I can't leave the computer processing alone.  Testing again.  Any suggestion?
I put an external cooler on the computer and the problem do not changed.
Only for information I use my computer for others softwares without any error, including, for astronomy,  DSS, Byos, PHD, Startools.
Thank you in advance,
« Last Edit: 2016 November 23 13:42:51 by fgbarr »
Re: Batch preprocessing turn computer off
« Reply #1 on: 2016 November 23 15:59:11 »
This is not a software bug, but a hardware-related problem in your computer. Typically, shutdowns are related to thermal management issues, and are more likely to happen on laptops. A workaround can be reducing the maximum number of processor cores used via preferences, but of course this will degrade performance.
