Author Topic: Plate solution info correctly represented in Fits header ?  (Read 899 times)
Offline ppistor
Observation (1): after image solution the FITS header showed a rotation angle that different from the angle showed in the image solution report of the process console. Call this Value "A".
Observation (2): When generating an image, using CatalogStarGenerator with parameters taken from the FITS data of image in (1), the resulting image is tilted against the image in (1).
Observation (3): When value A is used instead, the resulting image matches image in (1).
Observation (4): Similar observations can be made, if you start with an image generated by CatalogStarGenerator. The rotation value in Fits and the value used to genrate that image differ.
Peter.
