Author Topic: PixInight doesn't start after upgrade  (Read 1399 times)
Offline mmurphy3
« on: 2016 November 15 10:53:54 »
I have recently upgraded from Ununtu 15.10 to 16.10. I also upgraded PixInsight to the latest (01.08.04.1198)
The PixInsight installation proceeded exactly as expected (as documented on the forum) but when I launch it nothing happens.
I've tried running /pi-install/PixInsight/bin/PixInsight.sh but is says "command not found"
The first line of this file is
#!/bin/bash
is this correct?
Any ideas what's going on or how I can get some sort of diagnostic output that will tell me?
Re: PixInight doesn't start after upgrade
« Reply #1 on: 2016 November 15 14:42:24 »
Hi Mike, not sure but if the installation was well you can check if it run by clicking PixInsight.sh that you should have in the Root folder (/opt/PixInsight/bin/)
Saludos, Alejandro.
Offline mmurphy3
« Reply #2 on: 2016 November 15 23:40:24 »
Thanks Alejandro,
as mentioned in my post I've already tried this.
« Reply #3 on: 2016 November 16 00:13:29 »
Hi Mike,
If you have installed the application with default settings, the installer program creates a /bin/PixInsight launcher script, so you can run PixInsight anywhere on your filesystem by just saying PixInsight. The installer also integrates PixInsight with any freedesktop-compatible desktop manager, such as Gnome or KDE, so you should have a PixInsight application entry in the Graphics category of your launcher menu. Unless Ubuntu 16.10 has changed in a weird nonstandard way, which I seriously doubt, this must work.
At any rate, you should have an /opt/PixInsight directory. You can always run the installer program again, without parameters to perform a new standard installation.
A completely different problem is that if you have performed a clean Ubuntu 16.10 installation, then your system lacks a couple of required dependencies. See this thread for an easy solution to this issue.
Offline mmurphy3
« Reply #4 on: 2016 November 16 02:15:12 »
Hi Juan,
that was the problem. Installing the two packages from the 16.04 version fixed it.
Thanks very much for your help.
