Author Topic: DEBAYER  (Read 4058 times)
Offline orion10051976
DEBAYER
« on: 2016 November 05 11:53:21 »
dear all,
i'm facing a problem when debayering. i use a EOS550D mod Baader
summarize what i made til now:
in DSLR-RAW format explorer menu i set pure RAW.
i made superbias, master dark, master flat, calibrated my light frames, integrated all and i got a gray image (i applied STF)
when i try to debayer the image i get what you see on second image.
can someone help me?
if you need more details you can ask me
thank you very much
Offline gianpri
Re: DEBAYER
« Reply #1 on: 2016 November 05 12:14:29 »
You must apply debayer after calibration but BEFORE ImageAlignment  and ImageIntegration.
Re: DEBAYER
« Reply #2 on: 2016 November 05 12:18:30 »
thank you very much, i tried on a single calibrated file and i got a good image.
this means that i will have to debayer every single calibrated frame and then i have to align and integrate?
Re: DEBAYER
« Reply #3 on: 2016 November 05 13:14:47 »
In the Scripts menu under Batch Processing you will find a script called BatchDeBayer.
Offline gianpri
Re: DEBAYER
« Reply #4 on: 2016 November 05 13:21:28 »
Exactly. You can use the script Batch Processing and checking Calibrate only.
Re: DEBAYER
« Reply #5 on: 2016 November 05 14:01:10 »
I always use batch preprocessing script; this time i made all step by step in order to have full control for calibration frames and i forgot to make debayering before aling. Thank you very much for you quick help and suggestion
