Author Topic: Square shaped black lines round stars.  (Read 2602 times)
Offline Astrogaby
« on: 2016 October 28 09:51:05 »
Hi guys, I am wondering what is the cause of the square shaped dark margins round the stars? The telescope used was the TS71 349mmFL with QSI690. This is a preview of an RGB image Astrodon filters and Baader UHC-S Filter for light pollution. The image was produced using standard procedures and the final noise reduction was done using MLT.  Any help would be greatly appreciated.
Gaby
Re: Square shaped black lines round stars.
« Reply #1 on: 2016 October 28 10:24:46 »
check the registered subs for these artifacts, it may have been ringing caused by the StarAlignment interpolation algorithm. this can happen with undersampled images.
Offline Astrogaby
« Reply #2 on: 2016 October 28 10:38:11 »
Will do thanks.
Offline rdryfoos
« Reply #3 on: 2016 October 31 09:17:14 »
  Then how do folks make wonderfull images at 3.5 arcsec/pix?  I have run into this issue to at 2.58 arcsec/pix and clamping does not solve it--I have to go to nearest neighbor to solve it--but that is not supposed to be as accuirate--correct?
« Reply #4 on: 2016 October 31 10:34:56 »
drizzle can help with this problem, but as you've noted, besides that the only way to get around it is to use a different interpolation algorithm. the registration is accurate with other methods, but the registered images will be slightly less sharp. rather than nearest neighbor, you can try Bicubic Spline which is also pretty good and won't cause ringing to the extent that the default (lancosz-3) does.
Offline Astrogaby
« Reply #5 on: 2016 October 31 15:41:57 »
I have redone the stacking using Bicubic spline and indeed the dark lines have gone however there are now red/blue strings in the image now. Any ideas as to cause?
« Reply #6 on: 2016 October 31 16:04:25 »
pixel rejection settings in imageintegration should be able to take care of those.
