Author Topic: Process Container - AutoHistogram + HT  (Read 2222 times)
Offline rcolombari
« on: 2016 September 27 05:28:21 »
I have, let's say, N images.
I would like to apply to them (in automatic and with ProcessContainer):
Step 1: AutoHistogram (Logarithmic / target = 0.23 for all the images)
Step 2: HistogramTransformation to get the histo curve back to left until clipped pixels > 0
Step 1 is easy since the parameters are valid for all the images.
Step 2 varies, of course, from image to image.
Is there a way to automatically and dynamically implement step 2? Like, for instance, read the lowest X value for each image and pass it to the HT process?
Edit: I saw that the Statistic module gives exactly back the minimum X value. I should just understand how to call this module from inside the ProcessContainer.
Thanks.
Bests,
Roberto
Offline astroedo
  • Io ne ho viste... cose che voi umani...
    • L'arciere celeste
Re: Process Container - AutoHistogram + HT
« Reply #1 on: 2016 September 27 10:08:03 »
Hi Roberto,  you can use the clipping feature of AutoHistogram.
At the top of the process dialog you can enable the clipping value.
Experiment with the value to get the desired result.
Clear skies
Edoardo
Offline rcolombari
« Reply #2 on: 2016 September 27 16:44:05 »
Yeah, that's right!!
Thanks for the tip.
Bests.
Roberto
