Author Topic: Frustrated with Pix since last update  (Read 1488 times)
Offline eoverstreet
« on: 2016 September 26 18:50:29 »
Not too sure if the last update is the cause....but "scripted batch pre processing" has failed the last 4  attempts.....and worked fine prior to the last updates.  For example,   I started a batch script at 10 am.....by 4:00 pm it had slowed to a crawl.   I returned at 8 pm and Pix had disappeared.  Not too sure what is happening.   I am using 150 lights, 100 flats, 30 darks, 70 bias frames  - running updated MAC OS.  The Pix diagnostics give me a 'good to go" ok.
I have resorted to deep sky stacker - which works fine on my windows 10 machine....but would prefer not having to run both OS!
I don't have 8 hours to wait.   We need a fix, quick!
Frustrated!
Re: Frustrated with Pix since last update
« Reply #1 on: 2016 September 27 00:12:41 »
The only change in BatchPreprocessing 1.43 is a new Save process log option, which is enabled by default. This option simply creates a plain text file with the log of the process. You can try with this option disabled, but this action, by itself, cannot slow down anything under normal working conditions (if writing to a plain text file slows down your machine, then there's a serious problem that has nothing to do with PI).
The PixInsight core application that you are using has not changed since December 2015. The latest build 1199, in case you are using it, has not changed anything significant except being compatible with new macOS 10.12 Sierra installations.
There must be something in your machine, other than PixInsight, that has changed in a way that affects its performance adversely.
Problem solved then!
