Author Topic: SOLVED - HELP! Can't save my work!  (Read 2975 times)
Offline Greg Schwimer
« on: 2016 September 26 12:56:11 »
I'm kind of panicked about this..... ugh.
After several hours of working on a project, I opened a NoOp process and set some notes in it. My intention was to leave a reminder as to where I was in my processing. With the notes window open in a "committed" state, I selected Save Project. Now, I can't do anything. The save project dialog is open, as is the notes window, but I can't do anything with either of them. I can access all menus, but every option is greyed out. I can't change workspaces either to make sure that there is no open dialog waiting for input.
So, I can't save or do anything with my work.
Any ideas how to recover? Is there a CLI means to accessing PI externally that will force it to save off?
I'm running the latest PI version on OSX.
« Last Edit: 2016 September 26 13:19:07 by schwim »
- Greg
Scottsdale, Arizona, USA
Offline vicent_peris
    • http://www.astrofoto.es/
Re: HELP! Can't save my work!
« Reply #1 on: 2016 September 26 13:05:33 »
Just a ridiculous idea... Have you tried to press Esc key? I recently had a similar problem in a workshop (the interface blocked by a script interface that was not appearing) and it worked.
V.
« Reply #2 on: 2016 September 26 13:06:40 »
Not a ridiculous idea! I did try that. No bueno.
I think there is a dialog behind the notes window. I can't get to it though. The notes window won't move.
- Greg
« Reply #3 on: 2016 September 26 13:08:11 »
I am able to get PI to open other images by double clicking them in finder. However, I can't access the images. I just see them open in the background of the workspace.
- Greg
« Reply #4 on: 2016 September 26 13:11:32 »
I got it! This was very weird. I bet it can be reproduced.
To get to the dialog that was hidden behind the notes window I accessed a different application that only had a small window. That window came to the top of PI, and suddenly I could see the dialog. I clicked directly on the dialog and it let me drag it out from under the notes window. Weird.
- Greg
Re: SOLVED - HELP! Can't save my work!
« Reply #5 on: 2016 September 26 13:56:54 »
Well, that's a similar problem to what I described above. We should further investigate that, thank you.
V.
« Reply #6 on: 2016 September 26 13:59:41 »
I can submit this in bugs forum.
- Greg
