Author Topic: More an annoyance than a bug, but...  (Read 1251 times)
Offline LarryC
« on: 2016 July 29 12:50:00 »
When trying to open a saved cosmetic correction icon, if the master dark is not in the location specified when the icon was last saved it throws and error message, which would be fine, but when you proceed past the error notice, it resets everything related to master darks - old location, file name, hot pixels settings, etc.  I would much prefer that it not error on opening but rather error like other processes do upon application.  And I would much prefer that it allows me to find the master dark without deciding I need to reset all of my parameters.
Larry
Re: More an annoyance than a bug, but...
« Reply #1 on: 2016 July 29 13:04:37 »
Hi Larry,
I agree completely. We'll try to fix this issue as soon as possible. A workaround is:
1. Right-click the CosmeticCorrection icon.
2. Select Edit Instance Source Code.
3. On the editor window, set the value of P.masterDarkPath to the correct path to an existing master dark file.
4. Click the Commit button (green checkmark)
Now you can open the icon normally. Hope this helps.
« Last Edit: 2016 July 29 13:27:04 by Juan Conejero »
