Tim,
Like Alejandro said, that looks like a decon artifact that just gets worse with further processing. Here are tips for the decon deranging mask I picked up from others:
Local Support Deringing Mask:
As a first step try deconvolution without local deranging support. For many images, global deranging alone may be sufficient. If you need local deranging support, then build the deranging mask as follows:
Mask bright stars, but not just “super bright”
Look for strong red on bright stars, no protection on target
Pre-process image before applying StarMask
Duplicate image
Use MLT to remove 1st and residual wavelet layers in a 5 layer decomposition
Use StarMask on resulting image per below
Use Star Mask tool
Starting settings:
Noise threshold: 0.01
Scale: 3
Structure growth: 1-4-2
Smoothness: 16
Check “aggregate” and “binarize”
Do not check “invert”
If any of the target area remains (such as bright portions of galaxies), use CloneStamp tool to remove while leaving highlighted stars untouched
Smooth mask by applying a Gaussian Convolution
Start at settings of StdDev 5, Shape 2, and Aspect Ratio 1
Once satisfied, rename “Deringing mask”
Minimize for later use
It is VERY important to build a suitable local support for deringing: Try using a StarMask that covers well the brightest stars with 10-15 pixel of smoothness and truncation at about 0.75. Then fine trim deringing with a very small (usually less than 0.02) amount of global deringing.
Jim
