Author Topic: New in PixInsight 1.8.5: FrameAdaptation  (Read 14359 times)
Offline jkmorse
  • Two questions, Mitch . .
    • View Profile
    • Jim Morse Astronomy
Re: New in PixInsight 1.8.5: FrameAdaptation
« Reply #15 on: 2017 July 13 20:20:12 »
Geez, take a little time away to retire and have my hip replaced and all of a sudden, 1.8.5 is on the horizon  :D :D :D
Juan and Co., thank you so much for the continued dedication.  Gonna have lots to add to my workbook when all of these fun new tools start appearing in the update list.
Jim
New Mexico Skies Observatory
FLI Microline 16803
SkyX - MaximDL - ACP
Offline cdesselles
    • View Profile
« Reply #16 on: 2017 August 03 19:24:31 »
As usual, I am in complete awe of the time and talent put into PixInsight by the foremost astrophotography processing team on the planet. What you gentlemen do is nothing short of amazing.
  :surprised:
Offline mmirot
    • View Profile
« Reply #17 on: 2017 August 04 22:11:55 »
I don't see this in the release of 1.8.5.
Did it get cut from the release?
Max
    • View Profile
« Reply #18 on: 2017 August 04 23:44:39 »
it's called "LocalNormalization" now
Offline brew
    • View Profile
« Reply #19 on: 2017 August 07 11:40:24 »
I'm trying to get this to work, and have a couple of questions.
1) When I select a reference image in LocalNormalization, do I use one reference across all filters, or a separate reference for each filter set? I am currently using a Luminance image, the same one used for alignment.
2) When I use Subframe Selection, I specify a fits keyword to hold the calculated weight for the image (SSWEIGHT). I see this keyword in the approved images. However, after StarAlignment the aligned images do not contain the SSWEIGHT keyword. LocalNormalization runs against the aligned images, right? So, LN does not see the weights. This doesn't seem right. Doesn't ImageIntegration also need to see the weights?
3) When I run ImageIntegration against the aligned images (including the localNormalization files) the process console indicates that the local normalization data is found, but is not being used (green message). How do I make sure the files are being used? Is this due to the missing keyword, or something else?
Offline GordonH
    • View Profile
« Reply #20 on: 2017 August 08 18:23:33 »
I tried the new LocalNormalization with the Output Files stored in the same directory as the previously registered images.  The process runs to conclusion with a ".xnml" file for each of the image files.
In ImageIntegration I set Normalization to Local normalization but get:
"Warning: Local normalization data not available - No normalization will be applied!
Note: The image files are RGB
What am I missing?
    • View Profile
« Reply #21 on: 2017 August 08 20:38:23 »
you need to add the LN files to the ImageIntegration tool... there is a button to the left of the file list.
    • View Profile
« Reply #22 on: 2017 August 09 03:37:29 »
Please bear with us while we complete a few tutorials on the new tools released with PixInsight 1.8.5. LocalNormalization is a powerful but complex image analysis tool requiring a full description and detailed usage notes. The same applies to PhotometricColorCalibration.
Offline GordonH
    • View Profile
« Reply #23 on: 2017 August 09 12:19:02 »
rob,
Thanks, I should have payed more attention.
That did the trick.
Gordon
Offline RichInLesta
    • View Profile
« Reply #24 on: 2017 August 23 06:04:14 »
I just updated to 1.8.5 and was following the updated Pre-Processing instructions at http://www.lightvortexastronomy.com/tutorial-pre-processing-calibrating-and-stacking-images-in-pixinsight.html and hit a snag when adding the Local Normalization files.  I get the attached error.  I'm going to continue processing without adding the new normalization files, but would like to know if it's something I may have done incorrectly.
UPDATE 08.24.17:  I think I figured it out.  There's some ambiguity in the creation of the "normalized" images in the instructions on Light Vortex (just at this step!  The rest is awesome).  In the instructions, this step appears after the images have had the drizzle data added.  The step to add the normalization data files appears to use the PRE-DRIZZLED images; that is, the instructions themselves doesn't clarity this, and the accompanying graphic shows the pre-drizzled images.  It's when I used the pre-drizzled images that I received the attached error.  I re-ran the LocalNormalization process on the POST-DRIZZLED images, and I could then add the normalized image files that this created to the ImageIntegration process.
« Last Edit: 2017 August 24 06:33:49 by RichInLesta »
Offline joelshort
    • View Profile
    • Buckeyestargazer.net
« Reply #25 on: 2017 August 30 06:20:45 »
I'm playing around with the new LocalNormalization process and ImageIntegration process. My basic question is, is it ever possible that using LocalNormalization with rejection stacking will result in a slightly higher SNR than just stacking without any rejection (and therefore without LocalNormalization)?
I am finding that in many cases when I stack a set of images without rejection, and then stack with rejection and LocalNormalization, the LN stack has a higher SNR which doesn't quite make sense to me.
For example, I stacked a small set of 12-5min images.  Without rejection the SNR reported in the process console was 1.33+04.  When using Windsorized Sigma Clipping and LN the resulting SNR was 1.54+04.  This seems to be a common occurrence with small stacks of images.  However with larger stacks and using LinearFit rejection the resulting SNR is lower than the non-rejected stack, which is what I would expect.
Joel Short
www.buckeyestargazer.net
Offline alcol
    • View Profile
« Reply #26 on: 2017 September 11 06:05:25 »
Hi Rob, can you expand on where this button is. I am having trouble trying to find the xnml files after producing them with LocalNormalisation. I can see them in Windows File Explorer but ImageIntegration doesn't seem recognise xnml files and I can't therefore Add Files to ImageIntegration.
Probably something simple I am missing??
    • View Profile
« Reply #27 on: 2017 September 11 07:48:37 »
check the screenshot above, you'll see the button right under 'add files'
Offline alcol
    • View Profile
« Reply #28 on: 2017 September 11 09:42:51 »
Thanks Rob,
not sure why but my ImageIntegration input panel doesn't have these extra boxes in, it looks the same as the old version of PI. I downloaded the new version a few days ago and just checked and it says in the program files that it is the new version.
Presumably I should re-install the new version??
    • View Profile
« Reply #29 on: 2017 September 11 10:04:10 »
hmm, have you installed all the available updates? something is definitely wrong... maybe somehow the old version did not get uninstalled?
