Author Topic: Visualizing saturated / zero pixels  (Read 2642 times)
Offline mstriebeck
« on: 2016 July 06 12:55:23 »
I'm sure that this is trivial, but can't figure it out: how can I easily see which pixels in an image are either saturated or zero?
Background: I am fighting with an image where I keep clipping the histogram at the lower end. And I can't figure out where in the image that happens.
     Mark
Offline aworonow
    • Faint Light Photography
Re: Visualizing saturated / zero pixels
« Reply #1 on: 2016 July 06 13:45:02 »
Probably other answers, but you could use pixelmath. Something like
iif(CIEL($T)>.999,1,0)
set pixelmath a single RGB/K equation and to make a new image and drop its triangle on the image of interest . Could use, I suppose, 1.0 rather than .999, or a lesser value to see what is pushing the limit.
For this to function, all colors (RGB) must be saturated simultaneously (="diffused white")
alex
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #2 on: 2016 July 06 14:01:40 »
Enter in PixelMath the expression
iif($T<1,0,1)
drag the triangle over the image -
this creates an image which shows the saturated pixel only and sets all other pixel to Zero.
Or enter in PixelMath the expression
iif($T>0,0,1)
drag the triangle over the Image -
this creates an image which shows the pixels with Zero as bright pixels an the rest is set to black for better visibility.
This 2 Versions show very simple where either the black or white pixels are located.
Gerald
« Reply #3 on: 2016 July 06 15:04:54 »
You may also use the Binarize process.
« Reply #4 on: 2016 July 07 02:46:59 »
iif($T<1,0,1)
This is equivalent to:
$T >= 1
since a relational operator always evaluates to a Boolean value, which in the context of PixelMath corresponds to 0=false, 1=true.
A PixelMath expression that tells you which pixels are saturated at both ends of the histogram is simply:
$T <= 0 || $T >= 1
which can be read as if this pixel is zero or negative, or one or greater. For color images, more sophisticated results can be achieved if you use a different expression for each channel, but this is probably unnecessary for the task you are performing.
All of these expressions will create a binary image, that is, an image where a pixel can be either zero or one.
Offline mschuster
« Reply #5 on: 2016 July 07 07:46:44 »
Just a note that saturation (the condition where the well becomes filled) may occur at a value less than 1. On my QSI683 binned 2x2, on a long exposure of a bright star whose image is slightly bloomed in the uncalibrated frame, the maximum pixel value in the frame is ~0.83. This maximum varies slightly frame to frame about ~0.01.
Also note as the pixel value approaches saturation, the linear relationship between light intensity and signal degrades on CCD's with anti-blooming hardware. Several processes like DynamicPSF and MureDenoise don't work well on non-linear data near saturation.
« Last Edit: 2016 July 07 09:56:01 by mschuster »
