Author Topic: Working Scipts  (Read 6433 times)
Offline mmirot
Working Scipts
« on: 2009 January 06 19:59:39 »
Hi what scripts are working form this form.?
Most of the text  is in spanish so it is hard to follow sometimes using yahoo's translator.
Looks like some good scipts  such as column removal, star shaping and background adjusts.
 I can't get any of the scripts  to run from version 1.4.
 I am just using copying text into a *.js  file. and using excute script file
Keep up the good work! :)
Max Mirot
Offline David Serrano
Re: Working Scipts
« Reply #1 on: 2009 January 07 01:22:36 »
I would guess that any script published here is meant to work ;) so if you find problems running them, please ask here. The probability of receiving a good answer greatly increases if you copy & paste the output from the processing console if it contains any error.
 David Serrano
Offline mmirot
Working Scipts
« Reply #2 on: 2009 January 07 08:58:23 »
I am having trouble most are crashing.
I assume that I should be save the text as *.JS
Also, I am not sure what are the user inputs for a blank space the appear on some scipts at the end of the processing window.
Max
