Author Topic: Help with processing 2x2 binned RGB data with 1x1 binned Luminance data  (Read 3907 times)
Offline Watto
Hello,
My PI journey continues  :D and I need some guidance on processing 2x2 binned RGB data with 1x1 binned Luminance data.
Does any one have a work flow for processing this, if not could you point me in the right direction for which process to use?
Thanks in advance,
Watto
not too much to do differently - after calibrating the 2x2 images separately from the 1x1 images, you just need to register them to the 1x1 luminance data.
i think, though i'm not 100% sure, that BPP just handles this automatically.
Offline Watto
Thanks Rob! Appreciated.
Watto
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
Watto,
If you don't want to use or aren't using BPP, then the tool to use is Resample.  Resampling is a simple step, but absolutely critical if you shoot 2x2 binned RGBs with a 1x1 binned luminance.  Assuming you are shooting RGBs binned 2x2, then you just open the tool and double the size of your RGB image in both axes.   After that they have the same scale as the 1x1 luminance and everything else should work just fine.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Jim, that would amount to a double interpolation. StarAlignment itself will handle both the registration and the upsizing of the 2x2 bin images.
Offline jkmorse
Rob,
Point taken.  I have always just done the upscaling separate before the star alignment.
Jim
Apogee Aspen 16803
Offline Geoff
It does.
Don't panic! (Douglas Adams)
Offline niteman1946
Hi Rob, Jim, Geoff and Watto
A quick question.
Do 2x2 binned images require 2x2 binned Flats, Darks and Bias?
Mark
Hi Mark, yes absolutely. you might be able to get away with resized/software binned flats but it's better to make new ones at the right binning. for darks and bias its really necessary because the sensor characteristics (specifically read noise) will be different at bin 2 vs. bin 1.
Offline niteman1946
Thanks Rob.
I've done all at 1x1 up until now.  But I'm thinking about economizing on the RGBs.
Mark
Offline Watto
Thanks Jim, Rob, Geoff and Mark for the replies. I will have a look at Resample.
Watto
