First of all, let me say that pix insight is an incredible astrophotography editing program.
![smile :)](http://pixinsight.com/forum/Smileys/default/smile.gif)
However, when I move the mouse over the histogram transformation box, It draws incorrect material from other parts of the screen, or from behind the screen onto the two black boxes which are supposed to hold the dynamic histogram.
Therefore, in order to use this box properly, I need to very carefully avoid letting the mouse be over these black boxes.
The entire histogram box will redraw correctly if I move it slightly from the top.
I also have various problems with memory errors (similar to those in others have reported) such as PCL Win32 system exception -access violation: invalid memory read operation at address…
these seem to occur when I first load in .FIT files that I have downloaded from online telescopes. These also occur if I tried to do image registration from "views" of these files. So far, I found that if I'm very careful not to use the mouse wheel to zoom in on these files, and to immediately change to the local file format .xisf, then I'm able to avoid these errors. For image registration, I use "files" not views as the sources In the StarAlignment process.
I'm using Pix Insight Standard Edition 1.08.04.1195 Ripley X64, QT 5.5.1, Windows 10, 64 bit on a PC, Nvidia Quadro video card, 4K screen. I never have these kinds of errors in other applications, and am able to run prime 95 Etc. without problems.
