Garry, I suggest leaving Camera gain set to 1 and Data unit set to Data Numbers. Table values Median, MeanDeviation, and Noise will then be displayed in DN units, which should work very well. The alternative, specifying a gain and selecting e- units, is just for convenience and is not necessary IMO.
PS: If you do need gain for this or some other purpose, the FlatSNREstimator script can give a good estimate. You need two good flats and one good bias frame, all exposed at the same ISO, and all in undebayered raw CFA gray-scale format. Use the SplitCFA process to split these three frames into the four CFA channels each. Choose one of the G channels from each of the three (same channel in each) and run the script. The script will give a gain estimate that should be reasonably valid for all four channels. See the script documentation section 3.2 for an example. The script should give good results as long as your flats are well exposed.
