Author Topic: ImageRegistration module version 1.3.0.102 Now Available | Módulo ImageRegistration versión 1.3.0.102 Disponible  (Read 20293 times)
[Versión en Español al final]
Hi all,
A new version of the ImageRegistration module (1.3.0.102) is now available for all supported platforms. This version fixes bugs and adds important new features to the StarAlignment and DynamicAlignment processes. StarAlignment is a tool for automatic image registration that uses stars as alignment references. DynamicAlignment is an interactive tool for high-precision image registration based on manual selection of alignment features.
We encourage you to update your ImageRegistration module to this new version, as soon as possible.
Main Improvements and New Features
We have worked hard to improve our star matching algorithm, both in efficiency and performance. As a result of these improvements, StarAlignment is now able to register images accurately under much more difficult conditions than before. For example, now you can build wide-field mosaics with very little superposition (less than 1%) in just a few clicks, or register images with strongly dissimilar contents.
This new version of StarAlignment also includes an adaptive system to work out complex image registration problems. When the initial registration attempt using a maximum of 2000 stars fails, StarAlignment initiates a sequence of tries alternating reduced and expanded sets of stars adaptively, from just the 15 brightest up to a maximum of about 30000 stars. This covers most difficult situations due to strong differences in image contents, combined with little superposition between registered images.
Besides its powerful adaptive behavior, which allows for two-click automatic image registration in most situations, StarAlignment provides an exhaustive set of parameters to control every aspect of the feature-based image registration task: star detection, star matching and strong rejection of outliers (false star pair matches).
We don't hesitate to say that StarAlignment is probably the most versatile and accurate tool available for automatic, star-based image registration.
Download Addresses
Linux/X11 32-bit (x86):
http://pixinsight.com/export/ImageRegistration-pxm-x11-x86-20090104.tar.gz
Linux/X11 64-bit (x86_64):
http://pixinsight.com/export/ImageRegistration-pxm-x11-x86_64-20090104.tar.gz
Mac OS X 32-bit (x86):
http://pixinsight.com/export/ImageRegistration-pxm-osx-x86-20090104.zip
Windows 32-bit (x86)
http://pixinsight.com/export/ImageRegistration-pxm-win-x86-20090104.zip
Windows 64-bit (x86_64)
http://pixinsight.com/export/ImageRegistration-pxm-win-x86_64-20090104.zip
How to Install the Module
Linux
1. Exit all running instances of PixInsight, if any.
2. Extract the tar.gz archive and you'll get the module file:
  ImageRegistration-pxm.so
3. Copy the module to the bin installation subdirectory, replacing the previous version.
Mac OS X
2. Double-click the zip archive and you'll get the module file:
  ImageRegistration-pxm.dylib
3. Right-click the PixInsight.app application. It is on the /Applications folder if you copied it to that folder, as usual.
4. From the context menu, select Show Package Contents.
5. Now a Finder window opens for the PixInsight.app folder. Expand the Contents/MacOS/bin folder.
6. Copy the module file (step 2) to PixInsight.app/Contents/MacOS/bin
Windows
2. Extract the zip archive and you'll get the module file:
  ImageRegistration-pxm.dll
3. Copy the module to the bin installation sub-folder, replacing the previous version. If you installed PixInsight on the default location, then the required folder is C:\PCL\bin (C:\PCL64\bin for 64-bit Windows versions).
If you have suggestions or need help, don't hesitate to contact us at support@pixinsight.com, or at PixInsight Forum:
   http://forum.pixinsight.com/
Thank you for your continued support,
The PixInsight Team at Pleiades Astrophoto
Hola a todos,
Una nueva versión del módulo ImageRegistration (1.3.0.102) está disponible para todas las plataformas soportadas. Esta versión resuelve errores y añade importantes mejoras a los procesos StarAlignment y DynamicAlignment. StarAlignment es una herramienta para registro automático de imágenes que utiliza estrellas como referencias de alineación. DynamicAlignment es una herramienta interactiva para el registro de imágenes de alta precisión basada en selección manual de referencias de alineación.
Le recomendamos que actualice su módulo ImageRegistration a esta nueva versión lo antes posible.
Principales Mejoras y Nuevas Funciones
Hemos trabajado duro para mejorar nuestro algoritmo de emparejamiento de estrellas, tanto en eficacia y prestaciones como en velocidad de ejecución. Como resultado de estas mejoras, StarAlignment es ahora capaz de registrar imágenes con precisión bajo condiciones mucho más difíciles que en versiones anteriores. Por ejemplo, ahora puede construir mosaicos con un área de superposición muy pequeña (inferior al 1%) con tan sólo unos pocos clics, o registrar imágenes con fuertes diferencias en contenido.
Esta nueva versión de StarAlignment también incluye un sistema adaptativo para resolver problemas complejos de registro de imágenes. Cuando el intento inicial usando un máximo de 2000 estrellas fracasa, StarAlignment inicia una secuencia de intentos alternando conjuntos reducidos y ampliados de estrellas de forma adaptativa, desde sólo las 15 estrellas más brillantes hasta un máximo de alrededor de 30000 estrellas. Esto cubre la mayoría de las situaciones más difíciles debidas a combinaciones de fuertes diferencias en contenido y escasa superposición entre las imágenes registradas.
Además de un potente funcionamiento adaptativo, que permite efectuar el registro automático de imágenes con un par de clics en la mayoría de situaciones, StarAlignment proporciona un conjunto exhaustivo de parámetros para controlar todos los aspectos de la tarea de registro de imágenes: detección de estrellas, coincidencia entre pares de estrellas y rechazo de outliers (falsas parejas de estrellas).
No dudamos en afirmar que StarAlignment es probablemente la herramienta más versátil y precisa disponible para el registro automático de imágenes basado en estrellas.
Direcciones de Descarga
Cómo Instalar el Módulo
Linux
1. Termine todas las instancias de PixInsight en ejecución, si tiene alguna.
2. Extraiga el contenido del archivo tar.gz y obtendrá el archivo del módulo:
3. Copie el módulo a la subcarpeta bin de instalación, reemplazando la versión anterior.
Mac OS X
2. Haga doble clic en el archivo zip y obtendrá el archivo del módulo:
3. Haga clic con el botón secundario del ratón en la aplicación PixInsight.app, que estará en la carpeta Aplicaciones (/Applications) si la copió a esa carpeta, como es usual.
4. Desde el menú contextual, seleccione Mostrar Contenido del Paquete (Show Package Contents).
5. Ahora se habrá abierto una ventana de Finder para la carpeta PixInsight.app. Expanda la carpeta Contents/MacOS/bin.
6. Copie el módulo (paso 2) a PixInsight.app/Contents/MacOS/bin
Windows
2. Descomprima el archivo zip y obtendrá el archivo del módulo:
3. Copie el módulo a la subcarpeta bin de instalación, reemplazando la versión anterior. Si instaló PixInsight en la ubicación por defecto, entonces la carpeta en cuestión es C:\PCL\bin (C:\PCL64\bin para versiones de 64 bits).
Si tiene sugerencias o necesita ayuda, no dude en ponerse en contacto con nosotros en support@pixinsight.com, o en PixInsight Forum:
Gracias por su constante apoyo,
El Equipo de PixInsight en Pleiades Astrophoto
