www.pixinsight.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
https://pixinsight.com/forum/
News:
Home
Help
Search
Login
Register
PixInsight Forum (historical)
PixInsight
General
INDI
« previous
next »
Print
Pages: [
1
Author
Topic: INDI (Read 2858 times)
fcat
Newcomer
INDI
on:
2016 June 21 10:13:20 »
Dear
Please send me information by for INDI connection, I can not access the server
see attached
Best regards
Fcat
Logged
kkretzsch
PTeam Member
PixInsight Addict
Re: INDI
Reply #1 on:
2016 June 21 13:04:42 »
Hi Fcat,
which OS are you using? If you are using Windows you need to install the ASCOM framework and the wINDI server for windows from cloudmakers
http://www.cloudmakers.eu/windi/
The wINDI server is a wrapper of the ASCOM driver framework and translates the INDI commands to ASCOM commands and vice versa.
Please also see the initial INDI release post
http://pixinsight.com/forum/index.php?topic=9852.0
Best regards,
Klaus
Logged
fcat
Newcomer
Re: INDI
Reply #2 on:
2016 June 21 15:11:10 »
Hi Klaus
Installed W7 (64), ASCOM 6.2, 4.0 FW and windi (64) but
not connected
Best regard,
FĂ©lix
Logged
gianpri
Member
Re: INDI
Reply #3 on:
2016 June 22 06:11:42 »
I have the same problem: I win 10 (64), Windi, .NET 4.0 and 6.2 ASCOM. I always make the same mistake <INDI SERVER NOT CONNECTED>". Maybe they are incapable. Now I gave up. I'm sorry but I'll have to keep using ASCOM Platform.
John
Logged
kkretzsch
PTeam Member
PixInsight Addict
Re: INDI
Reply #4 on:
2016 June 22 06:47:18 »
Quote from: gianpri on 2016 June 22 06:11:42
No problem, but thanks for reporting this issue. It is indeed strange since connecting to a running INDI server should not be a problem. I'll download the latest wINDI server and try asap.
Logged
vicent_peris
PTeam Member
PixInsight Padawan
Re: INDI
Reply #5 on:
2016 June 22 06:57:14 »
This is a problem with the Windows firewall. You should let the wINDI application to go through the firewall. You can change the firewall configuration in the control panel.
Best regards,
Vicent.
Logged
gianpri
Member
Re: INDI
Reply #6 on:
2016 June 22 11:52:48 »
Thanks Vicent: problem solved. I modified the firewall settings. Now it all works.
John
Logged
Print
Pages: [
1
« previous
next »
PixInsight
General
INDI
