Author Topic: Unable to select TVGRestoration Local Support image  (Read 2878 times)
Offline Cosmick
When using TVGRestoration I am unable to select the Local Support image as the dialog box has shrunk and is unable to be resized.
64 bit Windows 7
See the attached image.
« Last Edit: 2016 May 22 00:45:53 by Cosmick »
Clear Skies
Mick
Re: Unable to select TVGRestoration Local Support image
« Reply #1 on: 2016 May 22 09:55:40 »
This bug will be fixed in the next release (already fixed the code). I'm redesigning the interface and some internal elements of both TGVDenoise and TGVRestoration. After this is done, I hope that both processes will make it into the standard distribution.
Offline Cosmick
« Reply #2 on: 2016 May 22 15:36:19 »
OK. Thanks.
Clear Skies
Mick
« Reply #3 on: 2016 June 05 20:20:55 »
Quick update. The code is in Juan's hands. We have to wait until he reviews the code and prepares a release if he thinks that is ready for inclusion in the core distribution.
From my end, this was the last update for this module. I'm working on a complete rewrite of TGV tools, with a faster algorithm (that also seems to give better results) but that needs a few extra parameters. I'm still far from a workable module, but some tests in scripted codes show a lot of potential.
