Author Topic: PI won't create swapfiles, says there's no space available  (Read 5415 times)
I'm attempting to do some processing with 1.4 on my laptop. There's about 90GB free on the C: drive. When I try to crop my image I get an error dialog stating there's no free space on my hard drive. I've verified that the chosen directory (%TEMP%) is correct and writable. I created a new directory (c:\temp\pixinsight_swap) and tried using that instead. Same result.
Any idea what's going on?
« Reply #1 on: 2008 December 23 15:02:47 »
I re-installed PI and now it works. Must have been a permission problem. Weird.
Offline David Serrano
« Reply #2 on: 2008 December 26 14:38:34 »
Quote from: "Nocturnal"
Yes, it is. I would suggest to save a copy of the configuration file before reinstalling in order to compare the old and new ones. I guess Juan will be glad to know about these "fixed after reinstall" issues.
 David Serrano
Offline Philippe B.
    • CIEL AUSTRAL
« Reply #3 on: 2008 December 27 03:34:17 »
I got the same message error and I also reinstalled then it worked. I aslo make a full reset configuration.
Offline Borja
« Reply #4 on: 2008 December 29 11:47:13 »
I an getting this problem if I change de temp directory to another location.
(I am administrator of the machine)
Regards.
PS.- I have a Vista 64 system
« Reply #5 on: 2008 December 29 12:56:39 »
Hmm, I just remembered a recent conversation about this. The suggested solution was to use the root of any disk as the swap directory. I don't know if the problem is present or fixed in 1.4.1 but I'd try it just in case.
 David Serrano
« Reply #6 on: 2009 January 02 01:13:28 »
Indeed, this is a bug in 1.4 (Windows version only). The application cannot retrieve the available space on Windows when the swap files directory is a sub-directory (non-root) of a removable device.
The work around is just to change the swap directory to a root directory on the removable disk, or much better, to a directory on an internal hard disk (non-removable):
- Edit > Global Preferences
- Select Directories and Network on the left panel.
- Remove the current directory from the Swap storage directories list.
- Add a new directory that simply points to the removable device, without any directory specification beyond the root. For example, F: or F:\, but not F:\my_temp_dir\pixinsight.
This will be fixed on 1.4.5.
« Reply #7 on: 2009 January 02 13:56:28 »
Hi Juan,
%TEMP% did not point at a removable device in my case. Re-install fixed it rather than changing the settings. Maybe whatever I experienced is fixed by the same update but my symptoms did not match your description I think.
