Author Topic: New INDIClient Module Released  (Read 76814 times)
Offline michael1026
Re: New INDIClient Module Released
« Reply #60 on: 2016 May 14 12:39:02 »
michael1026,
you can try solve your problem on INDI forum, because last is more suitable for similar questions about INDI.
Thank you. The thing is, if I run it locally using Ekos and not PI, the image is downloaded correctly. Do you think that's still an Indi problem, and not a bug with the new PI feature?
Offline Oleg Astro
  • Albufeira, Portugal
    • Ubuntu Astronomy 16.04
« Reply #61 on: 2016 May 14 12:44:55 »
michael1026,
See my screenshot in Reply #52.
Offline kkretzsch
« Reply #62 on: 2016 May 14 13:03:50 »
Yes this is strange. But downloading the image from the camera is something which is done on the INDI device side. The PI INDI client gets what is sent from the INDI server. I'll test this setup with my canon 500D soon.
« Reply #63 on: 2016 May 14 13:13:29 »
Have a way to have the client (PI)  save the file itself in addition to displaying it.
Yes, this is in our to-do list. This feature will be implemented very soon.
Allow the client to display the incoming frames with a restriction on which workspace they come in on
Unfortunately this is not possible right now because of some restrictions in our module development framework (PCL). This feature will be available in the next version of the PixInsight Core application, due before Summer.
Series runs - the ability to build multiple execution plans, e.g. 20x300 on lum, switch wheel to R, 20x300 lum binned 2x2, etc....
This is perfectly possible right now via scripting.
« Reply #64 on: 2016 May 14 13:16:01 »
Hi Oleg,
I have found a small bug in this INDIClient: I want to change the coordinates, but their submenu indicate
xx.xxxxxxxxxx deg 0 arcmin and 0 arcsec
instead
xx deg xx arcmin xx arcsec.
Oops! This bug is all mine. I'll try to fix it next Monday. Sorry for the trouble.
Offline Oleg Astro
« Reply #65 on: 2016 May 14 13:35:13 »
Hi Oleg,
instead
No problem :)
P.S. You can see PixInsight in INDI clients list.
Offline Greg Schwimer
« Reply #66 on: 2016 May 15 21:04:19 »
This is fantastic news! I ultimately would like to have this feature extended with live stacking of integrated subs, kind of a "continuous BPP". This would allow one to see the results of their data capture live.
I have the new INDI tools running on OSX with the Cloudmakers.eu INDI server. I am using simulators. It "just works" as far as I can tell.
Some thoughts:
  • Have a way to have the client (PI)  save the file itself in addition to displaying it.
It works in current version: you can change "Upload Mode:" in frame INDI CCD Controller.
Changing the upload mode to "server" causes the subs to be saved on the system running the server, no?
What I mean is that when PixInsight gets the file, it would be good if it can be configured to also save the file.
- Greg
Scottsdale, Arizona, USA
« Reply #67 on: 2016 May 15 21:19:58 »
Tested on OSX with Cloudmakers.eu INDI server. Great job!
- Greg
Offline Geoff
« Reply #68 on: 2016 May 15 23:20:07 »
In the "CCD Device" section of the "INDI CCD Controller" process you can choose the destination of the newly created image.
  • Upload to client only
  • Upload to INDI server only
  • Upload both: client and server
where
  • Means that the newly created image is transferred to the client and displayed in the PI app
  • Means that the newly created image is stored on the INDI server, i.e. the host where the INDI server is running
  • Means 1. & 2.
I tried connecting  a QSI camera.  The camera seems to work, but this section is greyed out. I can't locate any picture anywhere.
Geoff
Don't panic! (Douglas Adams)
Offline kkretzsch
« Reply #69 on: 2016 May 16 00:42:44 »
Thanks for testing.
Is on our Todo list.
« Reply #70 on: 2016 May 16 00:46:38 »
Not confirmed to be related to the INDI tools, but....
I haven't had a PI crash in a very long time, until I started playing with the INDI tools. Two crashes today alone. I'll keep digging to see if I can figure out a correlation.
- Greg
Offline kkretzsch
« Reply #71 on: 2016 May 16 00:59:18 »
Hi Geoff,
Can you send a screenshot? The combo box "Upload mode" shouldn't be greyed out, but  the fields "Server upload directory" and "Server filename template" are enabled only if you switch the "Upload mode" to Upload to INDI server only or Upload both: Client and server.
Offline kkretzsch
« Reply #72 on: 2016 May 16 01:04:16 »
One OSX  user already reported a crash when connecting to the INDI server.
« Last Edit: 2016 May 16 01:55:16 by kkretzsch »
Offline Oleg Astro
« Reply #73 on: 2016 May 16 02:30:06 »
Some thoughts:
INDIClient Module has three "Upload mode:"
1. Upload to client only
2. Upload to INDI server only
3. Upload both: Client and server
INDIClient Module is one from INDI clients. You can use many INDI cliens with one INDI server.
"Server" means minicomputer/laptot/desktop with installed indiserver and indi_drivers for astro hardware.
Look at my screenshot about last 3rd mode.
Offline Oleg Astro
« Reply #74 on: 2016 May 16 02:42:26 »
where
  • Means 1. & 2.
Geoff
It means:
1. INDI driver for QSI camera is run;
2. your camera is does not connected in INDIClient Module.
« Last Edit: 2016 May 16 04:09:36 by Oleg Astro »
