Author Topic: Script Console command  (Read 3116 times)
Offline CraigNZ
« on: 2016 May 04 22:21:16 »
A script can send text to the console for display, but can a script send a command to the console.  For example, can a script send a log command (log -f...) to open a log file.
Re: Script Console command
« Reply #1 on: 2016 May 11 01:24:54 »
This is not possible, both for security reasons and because the scripting engine is not reentrant. In the next version a module will be able to execute JavaScript code, under some security constraints.
You don't need the log command to do this from a script. Use the Console.beginLog() and Console.endLog() static methods. For example:
Console.beginLog();
// ... do your stuff here
let consoleText = Console.endLog().toString();
Let me know if this helps.
Offline CraigNZ
« Reply #2 on: 2016 May 11 12:31:32 »
Hi Juan,
I looked at the Console class but didn't see these .. I think this will do it.  Is there any documentation on them?
I think the call BeginLog is used to place all console messages to an array and endlog is used to stop it, and the contents of the byte array can then be written to a file.
If so, then if for example, AperturePhotometry, which calls other scripts is used, will the beginlog carry over into those scripts also, or is it capturing only the script it is called from?
Offline CraigNZ
« Reply #3 on: 2016 May 11 12:55:53 »
« Reply #4 on: 2016 May 11 13:45:26 »
Unfortunately not. Writing PJSR documentation is a long-standing pending task. Hopefully I'll find the necessary time---and motivation---to write it after completing other priority tasks I am currently involved in. I am always here to help, of course.
Well, it is actually more complex than that, but that's a valid top-level description.
Sure. For example:
Console.beginLog();
let consoleText = Console.endLog(); // consoleText = console text in UTF8 format
let file = File.createFileForWriting( "/path/to/file.txt" );
file.write( consoleText );
file.close();
Console text output will be recorded from the call to Console.beginLog() until Console.endLog(). As far as none of those scripts call Console.endLog(), console logging will work irrespective of what scripts are being executed.
Offline CraigNZ
« Reply #5 on: 2016 May 11 14:02:36 »
Thanks Juan, looks like this will do it .. I'll try it later today.
Craig
Offline CraigNZ
« Reply #6 on: 2016 May 11 22:00:07 »
Works perfectly. All of the console text is captured including those from called scripts.  What I can now do is make this an option on the output tab and enter a file name.  Checking the 'log file' box will then execute the log statements.  I will also add an option to generate a single log file or a log file for each image being processed.  This makes it easy then for traceability when examining the data further on or going back in the archives to see what I did.
Thanks heaps.
