Author Topic: Deconvolution and Star Masks  (Read 2536 times)
Offline tloebl
« on: 2016 April 28 15:41:43 »
I am having a bit of trouble with dark spots in the centers of bright stars after deconvolution. I have generated what I thought were effective star masks but for some reason running deconvolution with the star mask applied is ineffective. Looking for thought...
Tom
Offline niteman1946
Re: Deconvolution and Star Masks
« Reply #1 on: 2016 April 29 06:35:26 »
Hi Tom,
FWIW, I apply a "light" mask to the image and only cite the "star" mask in the Local Support section of Deringing section in Deconvolution.  I will also input a value into the Global Dark under the Deringing.  This value varies (at times) depending on the image and its condition.  However, generally speaking, the value of 0.005 works well for me.
And you'll need to do a Dynamic PSF process on the image and make sure that it is cited in the External PSF section of Deconvolution.
Hope this helps,
Mark
Offline tloebl
« Reply #2 on: 2016 May 02 17:56:16 »
Thanks Mark I'll have to try that. I was aware of having to use Dynamic PSF in the process...
Tom
