Author Topic: segmentation Violation  (Read 2547 times)
Offline whitenerj
« on: 2016 April 12 17:57:05 »
I'm using a macbook air and every now and then I'll get this "Segmentation Violation" error and have to close PI. Very annoying when I'm deep into a process and lose all my work. Is this a known bug? Any solutions?
Jason
Re: segmentation Violation
« Reply #1 on: 2016 April 13 08:37:23 »
Hi Jason,
No, segmentation violations should never happen under normal working conditions. That said, memory access errors do happen occasionally on all platforms, as a result of a variety of reasons, most of them hardware- and/or configuration-dependent, and in most cases machine-specific and difficult to identify.
The problem here is reproducibility. If you can find a repeatable sequence of operations, or a given working context, where the problem can be reproduced consistently, then it is obviously a bug and we can work to find, understand, and eventually fix it.
There have been no reports about segfaults associated with repeatable patterns on OS X or other platforms with the latest version. Are you using version 1.8.4.1195 of PixInsight on OS X, or an older version? Can you tell us something that could help us reproduce the problem?
