Author Topic: TGVRestoration and TGVinpaint  (Read 3522 times)
Offline mmirot
« on: 2016 April 06 10:58:00 »
Mars and the planets should be a good opportunity to test TGVRestoration. This is pretty complex tool.
Anyone been able to get good results? I have not seen any tutorials on how to use this.
What is the idea behind TGVinpaint? How do we use it?
We need some examples at least.
Max
Re: TGVRestoration and TGVinpaint
« Reply #1 on: 2016 April 06 11:40:51 »
Max
Here is the original write up from Carlos on the new TGV modules. http://pixinsight.com/forum/index.php?topic=8970.0
Also here are some examples I did using TGVInpaint. Nothing great but should give you some ideas how I have used it.
Remove Blooms TGVInpaint
https://drive.google.com/file/d/0B13r3kYqTf8NdHljTFhOTzUteEE/view?usp=sharing
TGVInPaint Star Removal and Replacement Regulus Image
https://drive.google.com/file/d/0B13r3kYqTf8NcXQzVnJuVmlUeGs/view?usp=sharing
TGVInPaint Star Removal Wide Field Orion
https://drive.google.com/file/d/0B13r3kYqTf8NcVozX2R6X1U1Y00/view?usp=sharing
Wide Field Star Size Reduction and Removal
http://www.astrobin.com/232469/0/
For the last link I used a 50 percent gray mask(PixelMath) applied to the image when using TGVInpaint. The star mask is made from the linear image(not stretched) using Statistics as the guide to setting the Mask Preprocessing parameters.
Offline mmirot
« Reply #2 on: 2016 April 09 06:46:19 »
Thanks Mike
Still need some tips with TGVrestoration best practices.  A whole lot sliders there. Planets are up. So does this improve on wavelets or Wiener ?
« Reply #3 on: 2016 April 09 10:21:47 »
Sorry Max but I haven't used Restoration yet. I should try it but I don't even use Deconvolution for my shots. Most of my shots are very low resolution so I haven't invested anytime yet.
Offline mmirot
« Reply #4 on: 2016 April 12 08:42:53 »
It Planetary session right now with Jupiter high in the sky and Mars and Saturn following.
That's what I am thinking about.  I have been able to get good results but I suspect I am missing a lot.
Btw, I generally don't do deconvolution on my deep sky stuff either.
Max
