Author Topic: Deconvolution on preview and main image give different results  (Read 2481 times)
Offline Buzz
    • The Astrophotography Manual - support
I did a search for this and found some historic mentions of the same thing but thought it might have been different now with the latest builds. The result of applying deconvolution to a preview and the main image is very different (for the same preview area). Is that supposed to happen?  (latest version on Win 10 )
thanks
regards
Chris
Re: Deconvolution on preview and main image give different results
« Reply #1 on: 2016 March 30 13:40:37 »
yeah it's normal...
« Reply #2 on: 2016 March 31 12:10:50 »
As Rob said, this is normal, specially if you are using ringing protection. The reason is that deringing (and also the wavelets regularization) uses a multiscale algorithm that makes the result dependent to the contents and scale of the image. Nevertheless, most of the time the parameters are close enough to fine tune it quickly using a preview of the full size of the image, after you reached a good set of parameters with the smaller ones (also, try using half a dozen of "small" previews in different parts of the image, to control the result with different structures).
Offline Buzz
« Reply #3 on: 2016 April 03 01:29:20 »
Thanks folks -   I might just be the excuse I need to buy a bigger Mac.  :)
regards
Chris
