Author Topic: Best way to make R,G, and B FWHM stars match the LUM channel?  (Read 3022 times)
Offline Aircrftr
I was wondering if anyone knows the best way to do this?  It would be great if we could have a process that would take our LRGB images before combining them, evaluate the FWHM of each channel and then deconvolve them to match the luminance channel (or whichever channel had the best image quality) and do it's magic to make them all the same.
Dan
Offline jkmorse
  • Two questions, Mitch . .
    • Jim Morse Astronomy
Re: Best way to make R,G, and B FWHM stars match the LUM channel?
« Reply #1 on: 2016 March 21 17:59:41 »
I have avoided the problem entirely by simply no longer shooting Lums.  I shoot RGBs only and create synthetic Lums from those stacks.  Works beautifully.  Check out this post on the logic:
http://pixinsight.com/forum/index.php?topic=6042.msg41068#msg41068
For what it's worth.
Jim
New Mexico Skies Observatory
Apogee Aspen 16803
SkyX - MaximDL - ACP
Offline Aircrftr
« Reply #2 on: 2016 March 21 19:28:53 »
I read the link you provided plus the links within those links and it seems like the LRGB subject has been kicked around and around without much resolution (pun)    The way I have always understood it, you shoot more luminance at the best times (good transparency and seeing and up towards zenith)  This gives you great detail.  Then shooting the RGB will always be lower resolution because its not all shot right at zenith.  For instance, I always shoot the red channel first in the series because the red penetrates the thicker air near the horizon better than the other colors.  The reason for shooting the RGB in 2X2 is that it would give better SN ratio and the fact that the chrominance only serves to colorize the detailed luminance channel. ( I actually do shoot RGB in 1X1 when the conditions will allow, to get better resolution when I can)  So in essence, you don't need highly detailed RGB because the way it is combined (in the LRGB combine process) the chrominance doesn't add much (perceived by the human eye) detail, but only colorizes the detailed luminance channel.  Now to my original question, It would be great to be able to match the sizes of the stars in each channel so that you don't get that multicolored star which is also bloated due to the RGB channels..(compared to the luminance)  Doing this via deconvolution for each channel separately would be hit and miss and pretty time consuming in my opinion.  It would be great to have a process that compares the PSF of the stars in each channel and run a deconvolution process that would match all three channels to the better stars in the luminance.
