Hello all,
Just given my 'second hand' QHY8L first light. Due to a rather annoying hardware issue I only managed to get x10 Lights each at 180 sec of the M81 / 82 pair.
Got x10 DARKS and x10 Bias calibration frames the next morning along with x10 FLATS but after running it all through BPP I ended up with an image with very light edges, seem this appears to be a common problem as I read across the Net but still cant seem to find a definitive answer to the problem.
I will attach a Gimp produced .jpg image of how my final integrated Light looks in Pixinsight with STF applied (unlinked) as the file seems to be a massive 210Mb in size (
![Shocked :o](http://pixinsight.com/forum/Smileys/default/shocked.gif)
What the hell's that all about
![Cool ????](http://pixinsight.com/forum/Smileys/default/cool.gif)
) so I cant really do anything with it, Dropbox complained !
I done my FLATS in the usual way using Sequence Generator Pro's FLAT's wizard using an EL panel which gave me exposure lengths of way less than 1 Sec and they over brightened the edges of the frame. After reading and reading on the net some were saying with a QHY8L, FLATS need to have an exposure time of over 4 sec's due to the dual readout issue. So with multiple pieces of white paper I kept adding these until I got above the 4 sec mark - Still bright edges !
More reading told me that my ADU of 25000 may be way too much so then I took a library of FLATS which had ADU's ranging from 10000 to 30000 with x10 exposures in each folder. The FLAT exposure times ranged from 4.1 sec all the way up to 19.6 sec so I could try different sets to find the 'sweet spot' for my camera.
The Over-illumination seen in the attached pic looks identical using the 10000 ADU flats AND the 30000 ADU flats and everything in between - Im confused to hell, my Canon 1000D used to produce perfect FLAT correction every time in Pixinsight
I have a master bias, dark and flat which was used to calibrate the x10 lights in the attached image in case anyone wants me to load them up for inspection, these are all 23Mb in size so if anyone wants me to load them up, just ask.
In spite of the over illumination problem and the fact that I was a little out of focus on the Lights, for only x10 Lights, im quite chuffed with the resulting image for a very inexperienced Astro photographer, a reasonable amount of detail in there I thought ?
One thing to note about the flats library, they were all done with the camera at zero degree's but the Lights were actually at approx. 99.1 degree's ref SGP's Framing & Mossaic wizard, not sure if this makes much difference but dust bunnies seemed to be in the same place on Lights and Flats.
So the questions:
1. Will the fact that I used Flats at zero degree's when light were at 99.1 cause what is seen in my image as the illumination is not only the corners ?
2. There appears to be differing opinions on the net - Should I make sure Flats are exposing above 4 sec when using a QHY8L ?
3. With a library of Flats ranging from 1000 ADU all the way to 30000 ADU - How can the BPP result look identical in all of them ?
4. HELP !
Ow please, someone help me here, this is driving me to drink !
Many thanks for anyone who can help me get sorted.
Regards
Paul
