The remote setup I have been using belongs to a friend that expects me to keep it busy. So far we're still getting everything up running properly. I build the computer to dual boot as the system is a TOA-150/STL-11000M and a 12.5" RC/STX-16803. It was easier for him to use having each system boot into which ever system he wanted to use and already have the software already configured, easier for me as well. Both sit side by side on an AP3600GTO with the optional encoders and limit switches. I think that mount can handle a 24" scope! The software is the same I use at home, ACP/MaxIm. To be exact, ACP Expert. This allows me to list a ton of projects and they get run depending on how I set up their constraints as far as minimum altitude, Moon avoidance, time before/after crossing the Meridian and a ton more. I set the series up by filters for LRGB, RGB, HaRGB and so on. I have targets that won't get done until next fall and that's OK. I just add them as I come across them. Using a rotator I have my FOVi setup in TheSkyX and use the J2000 coordinates along with the rotator PA. Sit back and wait for the data to pour in. For efficiency I calibrate the images on site via remote connection. I use Remote Desktop (secure firewall connection onsite), TeamViewer free, RealVNC, and LogMeIn. But I can also use the ftp server in ACP to transfer the raw data.
Make sure you take very careful attention to cable management because a snag there is way different than at home. While I do have Sam at SRO to do things that are needed he's not there 24/7 and he also has all the other systems to maintain as needed. If something comes loose or tangled it could be a day or two before its dealt with. A single setup should be much simpler.
HTH,
