Author Topic: BatchPreProcessing - Dark frame problem  (Read 2352 times)
Offline joecoyle
« on: 2016 March 08 12:20:36 »
Having not used PI for a while (and I'm only a beginner!) I came to take some images. I used the BPP script as usual to add in all the files / selected master dark / bias (no flat). These masters were created a few months ago. When I run the BPP script, it fails with this error:
* Begin calibration of light frames
* Searching for a master dark frame with exposure time = 120s -- best match is 120s
* Master bias: /Users/joe/Pictures/Astro/bias/superbias.xisf
* Master dark: /Users/joe/Pictures/Astro/2015-07-21/darks/masterdarkfeb.fit
ImageCalibration: Global context
Loading master calibration frames:
Loading calibration frame image:
Loading image: w=1391 h=1039 n=1 Gray Float32
26 FITS keyword(s) extracted.
Reading FITS image: 32-bit floating point, 1 channel(s), 1391x1039 pixels: done
31 FITS keywords extracted
Applying bias correction: master dark frame ...
Dark frame optimization thresholds:
Td0 = 0.00000000 (11 px = 0.001%)
** Warning: The dark frame optimization threshold is probably too high (channel 0).
** Warning: The dark frame optimization pixel set is too small - disabling dark frame optimization (channel 0).
*** Error: Unknown exception
<* failed *>
I've tried changing the dark frame threshold but it doesn't seem to affect the outcome. Still fails.
If I run the light frames through ImageCalibration, with the same master dark / bias, I get no errors and a set of calibrated frames.
Does anyone know what could be causing this? Could it be the age of my dark frames?
It always used to work in the past.
Just trying to save myself some time with the script!
Joe
Re: BatchPreProcessing - Dark frame problem
« Reply #1 on: 2016 March 08 13:59:24 »
Take a look at the fits preferences, and check if you are using the Top-Bottom orientation. Maybe there is an inconsistency there between the fits ans xisf files, so the information do not match.
