Author Topic: Grow of the PI window  (Read 2845 times)
Offline Joaquin Ballester
« on: 2016 February 28 13:59:41 »
running PixInsight Core 01.08.04.1195 Ripley (x64)  on  OSX 10.11.3 (15D21), on MacBook Pro (Retina, 15 pulgadas, mediados de 2015).
When first open PI, the main window fill all the screen of the macbook. Working normally with PI, the mail window auto-grow in horizontal from the right, so you end with a bigger main PI window than the screen. You have to resize the main window to continue working comfortably with the application.
Working normally mean open an image, apply some proceses, moving the inside windows, etc. In some moment, at the same time you make some process or move a window or what ever, the main window grow!
One of the process that make main window grow is DinamicBackgroundExtraction. Seems that the toolbar gets bigger, and make the window resize.
Joaquin.
« Last Edit: 2016 February 28 14:12:16 by Joaquin Ballester »
Re: Grow of the PI window
« Reply #1 on: 2016 February 28 15:16:21 »
Hi Joaquin, you may need to close or move to other position some Explorer windows or Tool bars. This video may give you an orientation.
Saludos. Alejandro.
« Reply #2 on: 2016 February 29 04:49:49 »
Dear Alejandro,
this issue is new in this version, and even i can tray to move, close or whatever the toolbar, process windows, etc.., is not a good behavior that the main window self-grow arbitrary with the use of the application, ending in a bigger window than the screen.
As far as i know, this must be a bug. Meanwhile i resize the window, every time i see this happen!
Saludos!
Joaquin.
Offline niteman1946
« Reply #3 on: 2016 February 29 09:47:16 »
Hi Joaquin,
see if my comments at the end of this thread are of any help to you.
http://pixinsight.com/forum/index.php?topic=9480.msg60586#msg60586
Good luck,
Mark
« Reply #4 on: 2016 March 01 14:21:41 »
hi mark,
changing the font size works too for me!
thanks
joaquin
