Author Topic: PixInsight 1.4.2 for Mac OS X Now Available | PixInsight 1.4.2 para Mac OS X Disponible  (Read 18183 times)
[Texto en Español al final]
PixInsight 1.4.2 (build 461) for Mac OS X is now available to our users. This is a bug fix release to solve a number of issues detected since the release of version 1.4.1 on December 12th.
Download Addresses
PixInsight 1.4.2 for Mac OS X is now available for download from our file servers:
* For commercial users (user name and password required):
      http://dist.pixinsight.com/
* For users of 30-day trial licenses:
      http://pixinsight.com/download/STD/
Installation
We encourage you to update your current installation as soon as possible. This is the recommended procedure:
Linux
   Not applicable.
Mac OS X
   1. Double click the .zip installation archive. This will create a PixInsight.app application bundle. PixInsight can be executed from any location, but we recommend copying PixInsight.app to the standard /Applications folder. You may want to add it to the Dock as well.
   2. If you are a commercial Windows or Linux user, your existing license file works fine on the Mac; you do not need to reactivate your license. Do the following:
      2.1 Locate your PixInsight license file. It is the .pixinsight-license file on your personal folder.
      2.2 Make a duplicate of .pixinsight-license and rename it to pixinsight-license (that is, the same name without a starting dot character).
      2.3 Copy the pixinsight-license file to your home folder on the Mac. Now you can run PixInsight for Mac OS X with your commercial license.
Windows
   Not applicable.
Main Bug Fixes
Version 1.4.2 fixes two critical errors found in the previous version 1.4.1 for Mac OS X.
Color Management [Mac OS X Only]. PixInsight didn't run on Mac OS X systems with active monitor calibration, due to a trivial error in version 1.4.1. Fixed.
AutoHide Windows [Mac OS X Only]. When one of these windows was detached from the application's main window (undocked, or floated), its title bar was initially located below the system menu bar, which prevented the user from moving or docking it with the mouse. Fixed.
Known Issues
Mac OS X. Color management still doesn't work for printing (File > Print). We hope to solve this issue as soon as possible. For now, just convert the image you want to print to the printer's profile, if necessary, before printing it with PixInsight.
We hope you'll enjoy this new version of PixInsight.
If you have suggestions or need help, don't hesitate to contact us at support_at_pixinsight_dot_com, or at PixInsight Forum:
   http://forum.pixinsight.com/
Thank you for your continued support,
The PixInsight Team at Pleiades Astrophoto
PixInsight 1.4.2 (build 461) para Mac OS X está disponible para todos nuestros usuarios. Esta versión corrige varios errores detectados desde la publicación de la versión 1.4.1 el día 12 de Diciembre.
Direcciones de Descarga
PixInsight 1.4.2 para Mac OS X está disponible para ser descargado desde nuestros servidores de archivos:
* Para usuarios comerciales (se requiere nombre de usuario y contraseña):
* Para usuarios de licencias de prueba de 30 días (30-day trial license):
Instalación
Le recomendamos encarecidamente que actualice su instalación tan pronto como le sea posible. Éste es el procedimiento recomendado:
Linux
   No aplicable.
Mac OS X
   1. Haga doble clic en el archivo .zip de instalación. Esto generará un archivo de aplicación con el nombre PixInsight.app. PixInsight puede ser ejecutado desde cualquier ubicación, pero le recomendamos que copie PixInsight.app a la carpeta estándar /Applications. Probablemente también querrá añadir PixInsight al Dock de Mac OS X.
   2. Si es usted un usuario comercial en Windows o Linux, su archivo de licencia funcionará perfectamente también en Mac OS X; no tiene que reactivar su licencia ni nada parecido. Haga lo siguiente:
      2.1 Localice su archivo de licencia de PixInsight. Es el archivo .pixinsight-license en su carpeta personal.
      2.2 Haga un duplicado de .pixinsight-license y cambie su nombre a pixinsight-license (o sea, el mismo nombre pero sin el punto inicial).
      2.3 Copie el archivo pixinsight-license a su carpeta personal en el Mac. Ahora puede ejecutar PixInsight para Mac OS X con su licencia comercial.
Windows
   No aplicable.
Principales Correcciones de Errores
La versión 1.4.2 soluciona dos errores críticos en la anterior versión 1.4.1 para Mac OS X.
Gestión de Color [Sólo Mac OS X]. PixInsight no se ejecutaba en sistemas Mac OS X con calibración del monitor principal activa, debido a un error trivial cometido en la versión 1.4.1. Corregido.
Ventanas AutoHide [Sólo Mac OS X]. Al separar estas ventanas de la ventana principal de la aplicación (modo 'floating') sus barras de título quedaban ocultas tras la barra de menú del sistema, con lo cual el usuario no podía moverlas. Corregido.
Problemas Conocidos
Mac OS X. la gestión del color aún no funciona para la impresión (File > Print). Esperamos resolver esto cuanto antes. Por ahora, asegúrese de convertir la imagen al perfil de la impresora, si es necesario, antes de imprimirla con PixInsight.
Esperamos que disfrute de esta nueva versión de PixInsight.
Si tiene sugerencias o necesita ayuda, no dude en contactar con nosotros en support_at_pixinsight_dot_com, o en PixInsight Forum:
Gracias por su constante apoyo,
El Equipo de PixInsight en Pleiades Astrophoto
