Hi all,
We are glad to announce the release of a new version of PixInsight: 1.8.4.1197 for Linux. Installation packages are now available to all users on our software distribution system.
Version 1.8.4.1197 is a bugfix/maintenance release for Linux platforms. The main improvements in this version are compatibility with glibc 2.22 (used by Fedora 23 and other cutting-edge distributions) and the latest versions of KDE Plasma 5, along with other bug fixes. We encourage all our Linux users to update their installations as soon as possible.
How to Install the ReleaseThis version is not available through the update system integrated with the PixInsight Core application. You have to download the appropriate installation package(s) for your platform(s) from our software distribution system:
https://pixinsight.com/dist/Once downloaded, uncompress the .tar.gz archive on a directory under your home directory, then run the installer program as root from a terminal. Answer "yes" to the confirmation question and you're done. The old version (if any) will be removed, and version 1.8.4.1197 will be installed on the /opt system directory by default, as usual. Graphical shortcuts will be created automatically on most X11 desktop environments, including GNOME, KDE, Xfce and LXDE.
See also FAQ Section 3 for important information about installations and updates:
http://pixinsight.com/faq/index.html#3_InstallationMain Bug Fixes- Fixed a bug that was causing a crash with immediate program termination on platforms using glibc 2.22. This mainly includes Fedora 23.
- Fixed several issues on the latest KDE Plasma 5 versions.
- On the View Explorer window with its extension hidden, newly loaded or created images were not generating new items in the main tree list on the left panel. This has been fixed.
- Files with white space characters in their file names were failing to open when launched from an external application, such as a desktop file manager, or passed as command-line arguments from a terminal as a result of wildcard expansion. This has been fixed.
I hope you enjoy this new release. Thank you all for your continued support.
