Author Topic: PixInsight 1.4.1 Now Available for Mac OS X, Linux and Windows | PixInsight 1.4.1 Disponible para Mac OS X, Linux y Windows  (Read 19110 times)
[Versión en Español al final]
Hi all,
PixInsight 1.4.1 is now available to our users on all supported platforms. This is a bug fix release to solve a number of issues detected since the release of version 1.4.0 on December 7th.
Download Addresses
PixInsight 1.4.1 is now available for download from our file servers:
* For commercial users (user name and password required):
      http://dist.pixinsight.com/
* For users of 30-day trial licenses:
      http://pixinsight.com/download/STD/
Installation
We encourage you to update your current installation as soon as possible. Before installing PixInsight 1.4.1, it is advisable to uninstall a previous version. This is the recommended procedure:
Linux
   1. Delete the whole directory where a previous version of PixInsight was installed.
   2. Unpack the .tar.gz file on a suitable directory, preferably one under the user's personal directory (for example, $HOME/PixInsight).
   3. To launch PixInsight, run the PixInsight.sh shell script on the bin installation directory.
Mac OS X
   1. Double click the .zip installation archive. This will create a PixInsight.app application bundle. PixInsight can be executed from any location, but we recommend copying PixInsight.app to the standard /Applications folder. You may want to add it to the Dock as well.
   2. If you are a commercial Windows or Linux user, your existing license file works fine on the Mac; you do not need to reactivate your license. Do the following:
      2.1 Locate your PixInsight license file. It is the .pixinsight-license file on your personal folder.
      2.2 Make a duplicate of .pixinsight-license and rename it to pixinsight-license (that is, the same name without a starting dot character).
      2.3 Copy the pixinsight-license file to your home folder on the Mac. Now you can run PixInsight for Mac OS X with your commercial license.
Windows
   1. Uninstall PixInsight. There is a Start > PixInsight Platform > Uninstall menu item that should be used. Never try to uninstall PixInsight by manually removing files.
   2. Run the PixInsight installation module for version 1.4.1.
   3. To launch PixInsight, go to Start > PixInsight Platform > PixInsight Core.
Main Bug Fixes
Version 1.4.1 fixes a small number of bugs that we have found since the release of the previous version 1.4.0. Most fixed bugs were of relatively minor importance, but some of them were critical. These are the most important bugs that have been fixed:
Color management [Mac OS X only]. PixInsight was not detecting the primary monitor profile on calibrated systems. We hope this issue will be fixed with this new version - please report any problems you find with color management on Mac OS X.
StarAlignment process. Due to an incorrect thread synchronization strategy, this process was causing a crash of the entire PixInsight platform. Fixed.
StarAlignment process. FITS header keywords, ICC profiles and metadata of target images were not preserved in the output registered images. Fixed.
ImageContainer. This interface was causing some crashes after opening a modal dialog. Fixed.
64-bit versions [Linux/X11 only]. Version 1.4.0 was compiled with SSE3 instructions. We have dropped them due to incompatibility with some AMD processors, so version 1.4.1 uses only SSE2 instructions on Linux and Windows. On Mac OS X however, SSE3 instructions are used.
Launcher script [Linux/X11 only]. The launcher script for version 1.4.0 started with #!/bin/sh; now it starts with #!/bin/bash for improved compatibility with Linux distributions.
Main New Features
New Preview > Show Previews main menu command. This command allows you to toggle visibility of preview rectangles on main image views. It works on a per-image basis, and is also available on the main view context menu (by right-clicking on a main view) and on the Preview tool bar. Thanks to Sander Pool for suggesting this new feature.
Integration of PixInsight Class Library (PCL) version 1.0.52
Improved handling of ICC profiles on all platforms.
Known Issues
Windows. The main menu seems disabled the first time the core application is launched. This is also apparent since everything works perfectly, and the disabled appearance disappears :) as soon as you open a file or any processing window. We'll try to fix this glitch as soon as possible.
Mac OS X. Color management still doesn't work for printing (File > Print). We hope to solve this issue as soon as possible. For now, just convert the image you want to print to the printer's profile, if necessary, before printing it with PixInsight.
We hope you'll enjoy this new version of PixInsight.
If you have suggestions or need help, don't hesitate to contact us at support_at_pixinsight_dot_com, or at PixInsight Forum:
   http://forum.pixinsight.com/
Thank you for your continued support,
The PixInsight Team at Pleiades Astrophoto
Hola a todos,
PixInsight 1.4.1 (build 460) está disponible para todos nuestros usuarios. Esta versión corrige varios errores detectados desde la publicación de la versión 1.4.0 el día 7 de Diciembre.
Direcciones de Descarga
PixInsight 1.4.1 está disponible para ser descargado desde nuestros servidores de archivos:
* Para usuarios comerciales (se requiere nombre de usuario y contraseña):
* Para usuarios de licencias de prueba de 30 días (30-day trial license):
Instalación
Le recomendamos encarecidamente que actualice su isntalación tan pronto como le sea posible. Antes de instalar PixInsight 1.4.1, es recomendable desinstalar la versión anterior. Éste es el procedimiento recomendado:
Linux
   1. Borre el directorio completo donde instaló la anterior versión de PixInsight.
   2. Descomprima el archivo .tar.gz en un directorio cualquiera, preferiblemente en uno bajo su directorio personal de usuario (por ejemplo, $HOME/PixInsight).
   3. Para lanzar PixInsight, ejecute el script PixInsight.sh desde el directorio bin de instalación.
Mac OS X
   1. Haga doble clic en el archivo .zip de instalación. Esto generará un archivo de aplicación con el nombre PixInsight.app. PixInsight puede ser ejecutado desde cualquier ubicación, pero le recomendamos que copie PixInsight.app a la carpeta estándar /Applications. Probablemente también querrá añadir PixInsight al Dock de Mac OS X.
   2. Si es usted un usuario comercial en Windows o Linux, su archivo de licencia funcionará perfectamente también en Mac OS X; no tiene que reactivar su licencia ni nada parecido. Haga lo siguiente:
      2.1 Localice su archivo de licencia de PixInsight. Es el archivo .pixinsight-license en su carpeta personal.
      2.2 Haga un duplicado de .pixinsight-license y cambie su nombre a pixinsight-license (o sea, el mismo nombre pero sin el punto inicial).
      2.3 Copie el archivo pixinsight-license a su carpeta personal en el Mac. Ahora puede ejecutar PixInsight para Mac OS X con su licencia comercial.
Windows
   1. Desinstale PixInsight. Hay una opción del menú Inicio > PixInsight Platform > Uninstall que debería utilizar. Nunca intente desinstalar PixInsight eliminando archivos manualmente.
   2. Ejecute el módulo de instalación para la versión 1.4.0.
   3. Para lanzar PixInsight, vaya a Inicio > PixInsight Platform > PixInsight Core.
Principales Correcciones de Errores
La versión 1.4.1 soluciona un pequeño número de errores que hemos encontrado desde la anterior versión 1.4.0. La mayoría de los errores corregidos eran relativamente poco importantes, pero algunos de ellos son críticos. Éstos son los principales errores que han sido corregidos:
Gestión de Color [sólo Mac OS X]. PixInsight no estaba detectando el perfil del monitor principal en sistemas calibrados. Esperamos que este problema se resuelva con esta versión - por favor, informe de cualquier problema que tenga con la gestión del color en Mac OS X.
StarAlignment. Debido a una estrategia incorrecta de sincronización de threads, este proceso estaba causando un caída de toda la plataforma PixInsight. Solucionado.
StarAlignment. Las cabeceras FITS, los perfiles ICC y los metadatos de las imágenes alineadas no estaban siendo conservados en las imágenes registradas producidas. Solucionado.
ImageContainer. Esta interfaz estaba causando varias caídas al abrir ventanas de diálogo. Solucionado.
Versiones de 64-bit [sólo Linux/X11]. La versión 1.4.0 había sido compilada para utilizar instrucciones SSE3. Hemos decidido no seguir usando estas instrucciones debido a incompatibilidades con algunos procesadores AMD, así que la versión 1.4.1 usa sólo instrucciones SSE2 en Linux y Windows. En Mac OS X sin embargo, las instrucciones SSE3 sí son utilizadas.
Script de lanzamiento [sólo Linux/X11]. Este script comenzaba por #!/bin/sh en la versión 1.4.0; ahora comienza con #!/bin/bash para mejorar la compatibilidad con diversas distribuciones de Linux.
Principales Nuevas Características
Nuevo comando de menú Preview > Show Previews. Este comando permite activar/desactivar la visibilidad de los rectángulos de previsualizaciones en vistas principales. Funciona de forma independiente para cada imagen, y también está disponible en el menú contextual de imagen (haciendo clic con el botón secundario en una vista principal) y en la barra de herramientas Preview. Gracias a Sander Pool por sugerir esta nueva función.
Integración de PixInsight Class Library (PCL) versión 1.0.52
Gestión mejorada de perfiles ICC en todas las plataformas.
Esperamos que disfrute de esta nueva versión de PixInsight.
Si tiene sugerencias o necesita ayuda, no dude en contactar con nosotros en support_at_pixinsight_dot_com, o en PixInsight Forum:
Gracias por su constante apoyo,
El Equipo de PixInsight en Pleiades Astrophoto
