Author Topic: MaskedStrech unable to auto strech (to dark image)  (Read 3619 times)
Offline gvanhau
« on: 2016 February 13 09:53:02 »
Hello
This is new to me;  I've never had problems with this.
I attached screenshot  of PI, where you can see the console output, the error message and the image I'm processing.
Geert
Geert Vanhauwaert
Re: MaskedStrech unable to auto strech (to dark image)
« Reply #1 on: 2016 February 13 15:24:55 »
Hi Geert, you have to set a Background reference of the image with the value of Upper limit. That should solve the error.
This process example may help.
Saludos, Alejandro.
Offline gvanhau
« Reply #2 on: 2016 February 14 18:11:55 »
Hello Alejandro.
The background reference is the image itself (target).
I never had to set a different background refentece before.
Geert Vanhauwaert
« Reply #3 on: 2016 March 11 00:51:56 »
No bug here, just normal behavior. However, everything is guess work without the image in question.
Offline gvanhau
« Reply #4 on: 2016 March 31 09:02:13 »
Sorry Juan I Did'nt see your reply. By this time I already found a work arround (using the masked stretch script).
It may be usefull to include the minimum level where this procedure can be applied in a tooltip.
Regards
Geert Vanhauwaert
