I had included 8 images of M51 to align and used a previously aligned image as the reference. On first attempt the alignment failed on each image. Second attempts, same series and same process instance, it all worked.
Below is a segment of the Process Console:
Registering target image 1 of 8
Loading target file:
G:/Images/M51/PI_Cal/M51-001-L-090-E_dupe-12_c.fts
Reading FITS image: 32-bit floating point, 1 channel(s), 4008x2672 pixels: done
153 FITS keywords extracted
Structure map: done
Detecting stars: done
494 stars found.
Matching stars: done
*** 0 star pair matches found - need at least six matched stars.
* Previous attempt failed - this is try #2
useScaleDifferences=false
295 putative star pair matches.
Performing RANSAC: done
279 star pair matches in 220 RANSAC iterations.
Summary of model properties:
Inliers : 0.946
Overlapping : 1.000
Regularity : 0.974
Quality : 0.886
Root mean square error:
delta_RMS : 0.755 px
RMS error deviation:
sigma_RMS : 0.287 px
Peak errors:
delta_x_max : 1.935 px
delta_y_max : 1.567 px
Transformation matrix:
+0.9743 +0.0024 +54.2292
-0.0028 +0.9743 +52.9173
+0.0000 -0.0000 +1.0000
scale : 1.027
scale-X : 1.026
scale-Y : 1.026
rotation : -0.15 deg
dx : +54.23 px
dy : +52.92 px
Generating registered image
Homographic Projection / Lanczos-3 interpolation, c=0.15: done
Registration successful.
Writing output file: G:/Images/M51/PI_Cal/aligned/M51-001-L-090-E_dupe-12_c_r.fit
174 FITS keywords embedded
Writing FITS image: 32-bit floating point, 1 channel(s), 4008x2672 pixels: done
Registering target image 2 of 8
G:/Images/M51/PI_Cal/M51-001-L-090-E_dupe-13_c.fts
Structure map: done
460 stars found.
290 putative star pair matches.
273 star pair matches in 166 RANSAC iterations.
Inliers : 0.941
Overlapping : 1.000
Regularity : 0.974
Quality : 0.882
delta_RMS : 0.775 px
sigma_RMS : 0.310 px
Peak errors:
delta_x_max : 1.974 px
delta_y_max : 1.543 px
+0.9740 +0.0030 +72.0915
-0.0033 +0.9744 +42.8474
-0.0000 -0.0000 +1.0000
scale : 1.027
scale-X : 1.027
scale-Y : 1.026
rotation : -0.17 deg
dx : +72.09 px
dy : +42.85 px
Writing output file: G:/Images/M51/PI_Cal/aligned/M51-001-L-090-E_dupe-13_c_r.fit
