Author Topic: Pure Raw option weirdness  (Read 2335 times)
Offline alex.vasenin
« on: 2016 February 03 12:53:46 »
I've recently discovered CosmeticCorrection tool removes hot pixels much better from non-debayered CFA images rather than from debayered RBGs. So I switched Raw format preferences from the default de-Bayer RGB to Pure Raw and tried make my master bias/dark/flat frames and calibrate my lights in non-debayered form, and debayer them after calibration. It looks like it works OK, but I found one strange thing I can't explain.
If I open single bias frame (1/4000) and single dark frame (5 min) with de-Bayer RGB option the images statistics are consistent with a theory: mean value of the dark frame is about twice as high as mean of the bias frame, and standard deviation of the dark is about three times higher than standard deviation of the bias.
However, if I open the same files with Pure Raw option, the mean value of the bias and the dark frames are almost the same! The only difference is standard deviation. By definition, raw dark frame contains both the bias pedestal and the dark current, while raw bias frame contains only the bias pedestal. How on Earth they can be the same? Any ideas on what's going on?
Re: Pure Raw option weirdness
« Reply #1 on: 2016 February 04 13:49:41 »
I've figured it out: Canon preprocess their RAW files so average value of the dark current is close to zero after that  :-[
