Author Topic: PixelMath process don't works  (Read 2528 times)
Offline jbmerillot
« on: 2016 February 03 06:20:11 »
Hello from France,
I subscribe to a training session in some days, and I had to test the PixelMath process.
Whatever I do (even if I leave the fields blank), I got this message. Any idea?
Thanks.
« Last Edit: 2016 February 03 06:37:41 by jbmerillot »
Offline niteman1946
Re: PixelMath process don't works
« Reply #1 on: 2016 February 03 08:12:10 »
Try using the blue square instead of the blue circle.
Offline jbmerillot
« Reply #2 on: 2016 February 03 12:17:42 »
It works!
Thanks.
Offline oldwexi
    • Astronomy Pages G.W.
« Reply #3 on: 2016 February 03 12:35:47 »
Hi JB!
The error message says clearly:
,,,because some of it s  Parameter depend on a particular   target Image .
You have selected "Replace target Image" this does not cooperate with the blue ball
as there is no target Image in global mode..
So if you execute with the triangle there is a target Image
If you execute with the blue square the actual (blue bar) Image will be used as target image.
The blue circle does not work with "Replace target Image"
Blue circle works nicely with "Create new Image" and the associated parameter.
Gerald
