Author Topic: DynamicPSF question  (Read 2172 times)
Offline CraigNZ
DynamicPSF question
« on: 2016 February 02 19:59:29 »
When "Moffat" is selected, what beta parameters are tested?  Does it do some sort of range test and narrow in on a best beta by comparing MAD results?
Also, if "Auto" is selected, how does it select the beta parameter, also by searching?
Re: DynamicPSF question
« Reply #1 on: 2016 February 03 00:28:09 »
When the Moffat and Auto model functions are selected, DynamicPSF fits the beta parameter with the Levenberg-Marquadt algorithm. Note that this is not a search procedure; beta is fitted just as A, B, cx, cy, sx and sy (and r and theta when fitting an elliptic function).
In Auto mode, the process fits Gaussian and variable-beta Moffat functions, then selects the model with the least residual.
Offline CraigNZ
« Reply #2 on: 2016 February 03 13:09:26 »
So if I got this right, Moffat (or Auto) will try a few beta values and then do a Levenberg-Marquadt algorithm (least squares fit) of the values to derive the optimal beta value?
