Author Topic: File Explorer Question  (Read 2476 times)
Offline tloebl
« on: 2016 February 02 09:10:05 »
I use my network drive to store images. I can't seem to be able to access the network with File Explorer. Is this a normal condition? I am using Windows 7.
Tom
Re: File Explorer Question
« Reply #1 on: 2016 February 03 00:48:36 »
Hi Tom,
Currently File Explorer does not provide direct access to network resources. However, you can mount your network drive (or a directory on it) on your local filesystem. In this way File Explorer will give you access to the mounted resource, just as a regular folder. We do this all the time and works perfectly.
On Windows, you can simply create a shortcut to your network drive (this is called "mapping" on Windows 10, but works the same). On Linux/UNIX operating systems, network resources can be mounted on the local filesystem tree very easily with the mount command. On OS X, you can also map a network drive to a folder on your desktop using the graphical user interface.
Offline tloebl
« Reply #2 on: 2016 February 03 05:27:00 »
Thanks Juan, mapping a drive solved my problem...
