Author Topic: virtual bool IsHistoryUpdater(const View& v) const  (Read 4880 times)
Offline NKV
« on: 2016 January 27 02:16:39 »
As you know there are two type of modules:
type 1: create new image (for example Debayer ), which not compatible with ImageContainer
type 2: modify image (for example Crop ), which compatible with ImageContainer
I try to write some module, where user can choose where save result: to new image or to processed image.
My question: what should i do with PCL function:
    bool MyModule_Instance::IsHistoryUpdater(const View& view) const
        return true; // we are change source image, it's good for type 2 strategy
But, what about type 1? How to reset modification flag in source View?
PS or, can: return myModificationFlag;
« Last Edit: 2016 January 27 02:48:02 by NKV »
Re: virtual bool IsHistoryUpdater(const View& v) const
« Reply #1 on: 2016 January 27 03:46:52 »
Your reimplementation of ProcessImplementation::IsHistoryUpdater() should tell the core what happens to an image's history if a particular instance (the instance pointed to by this) is executed on the image, so,
is correct. More explicitly:
class MyInstance : public ProcessImplementation
public:
   MyInstance();
   virtual void Assign( const ProcessImplementation& );
   virtual bool IsHistoryUpdater( const View& ) const
      return !p_createNewImage;
private:
   pcl_bool p_createNewImage;
Offline NKV
« Reply #2 on: 2016 January 27 19:00:37 »
Thank you!
