Author Topic: Debayer module 64bit support  (Read 3540 times)
Offline NKV
« on: 2016 January 20 20:22:56 »
Debayer module 64bit support.
is it possible?
Re: Debayer module 64bit support
« Reply #1 on: 2016 January 21 03:12:56 »
It should be possible. However, does that make sense?
CFA arrays are 16-bit integer data, so I don't see how interpolating them to 64-bit floating point numbers could be of any benefit. Currently, the Debayer process generates a 32-bit floating point image, which is much more than sufficient IMO.
Or are you planning to do something more creative here ?  ???
Offline NKV
« Reply #2 on: 2016 January 21 03:34:25 »
Night landscape images series without StarAlignment:
RAW >> CFA_RAW 16bit >> Calibrate to 32 float >> Integrate to 64bit >> SplitCFA >> same linear 64bit processing >> MergeCFA 64bit >> Debayer RGB
